Mitsubishi WS-55909 55" Rear Projection Television Logo
Terrie Lattz Posted on Jan 23, 2014
Power button flashing gree and tv will not turn on
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
1helpful
Our50inch sony projection tv model KF-WE50A1/5 when i turned on gree indicator light flashing only no picture no sound
sir,i have sony wega projector tv 50''.this alrady working good.but I don't know HD DVD1,HD DVD2 where pluging? model no KF-WE50A1/5...ser no.5002432.sony corp
1helpful
How can i reset my canon pixma ip1300?
1. turn off canon ip1300
2. hold down resume button then press power button
3. keep holding down power button and let resume button go
4. press resume button 2X then let buth button go
5. green light will flash and then stop blinking
6. when gree light are solid press resume button 4X
7. press the power button, your printer canon ip1300 will turn off, if no press power button ance again
8. press power button to turn on printer, and your printer should response normal
i hope this helpfull
thanks for using fixya
1helpful
Power light is flashing green. i hold the power button it turns red. i press it again it turns yellowish then solid gree the screen comes on the 3 second later screen goes blank and flashing green power
Sharp tv are famous for this problems.Take ur tv aparts,where the a/c power cord go into it.That ur tv power supply board,check for all those dead leakage capacitors parts that bulges up on it top or puff up on it top.Than it ur power supply board,replaced those dead leakages capicitors or replaced the whole power supply board.No leakage capcitors on the power supply board.Than it 100% the Tuner board it dead,this board is where the coalax broacast tv signal cable go into it.This board can't not be repair only replaced,because it alway some ICS it the problems it dead on this Tuner board.Tries websties like Shopjimmy.com,Ebay.com to buy either or both refurbishes the power supply board or the Tuner board.
1helpful
HOW do you reset the timer>? the lights on front of the tv flash 3 gree then 2 orange. Says to replace lamp,which I did then reset timer...HOW?
press "menu" button, scroll down to "special features" and press "ok" button, scroll down to "reset lamp timer" and press "ok" button, you will notice the "no" change to "yes" and press "ok" button, you will notice "yes" change to "no", this will reset the lamp timer
Hi my name is lily i have a ploblem with my tv is proscan 19inchla25q i try to turn it on but it wont go on the red ligt flashes gree then it turn back on in red
The power supply is bad. It supplies enough power to light the red LED when the tv is powered off, but not enough to power up the tv. You can find one on ebay.
Error light
There is an error code that flashes on front of TV. which is in this case an error 7 which is power related. Also there is a gree LED on the power supply that will flash an error code also. If u look on the power supply U will see a list of numbers 1-13 which list the error codes and what they mean.Usually if it flashes 1-9 its usually cheaper to just buy another TV. because the Power supply , Y-main, X-main will probably run $300 plus core charge.
Can not reset tv
These sets have a common problem with the front panel buttons sticking and not allowing the set to turn on. Unplugging the control panel and using the remote to turn the set on normally diagnoses that problem (If you try this, remember that once the set is origionally plugged in, it takes about a minute and half before the set can be turned back on. Another problem could be in the convergence circuit. If you hit the power button and the indicator light comes on and shuts off then that is the circuit that is most suspect. The -24 volt line fusible link as well as the 24 volt line will open up if the convergence IC shorts out. There is a way to diagnose this set by pushing in and holding the menu and device button on the set at the same time until the indicator light starts flashing. There are two sets of flashes, such as, 2 flashes and then 3 flashes. Hope this helps.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
