Question about LG DLEX7177WM SteamDryer Front Load Electric Dryer, White, 7.3 cu. ft. Ultra Capacity with NeveRust Stainless Steel Drum, 5 Temperature Levels, 5 Drying Levels, 9 Programs, TrueSteam Generator Produces Real Steam, SteamFresh CycReduces Wrinkles and Odor
Drum doesn spin
Drum doesn't spin
    Guru:
  • 78 Answers
If this product is new, you will need to take out the carriage bolts located in the back of the machine.
Carriage bolts are meant for the shipping process to prevent the drum from moving while in transit. Most manufacturers use between 2-4.
Check your product manual for details on the removal of the carriage bolts
Posted on Jan 23, 2014
Washer does not spin. Makes noise but drum doesn’t move
replace the rubber drive belt, unplug the machine remove the back panel to reach it as they do get worn and will wash but as the load sits at the bottom of the drum in spin mode the drum becomes heavier when the washing is sitting in the bottom its harder to start the rotation eric
Jan 18, 2018 | Washing Machines
Hotpoint WF100 doesn't spin
its a stretch fit belt ,give it some application and it will fit
Dec 01, 2012 | Washing Machines
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Drains but drum wont spin
see this probably causes:
t spins, but doesn't pump
see for glogged drain line
It doesn't spin or pump
see the pump pulley frozen
It pumps, but the water returns
slow drain, improve the drain see the attachement
May 08, 2012 | Washing Machines
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
During the spinning cycle machine makes grunting noise and it doesn't spin. After few minutes of only noise all the lights on the dial are flashing and it doesn't do anything else. The doors are...
Sounds like you have some thing caught in the drum and/or drum bearing has give up the ghost---another thought is the drum brake is being applied while trying to spin--something could be out of sequence with timer and/or wires crossed/shorted causing functions at wrong time---can you spin it when it's off ?? the reason being you can't open the door while running is a safety factor--water doesn't run on floor--somebody getting arm caught in drum etc etc----do you have the operating manual--if so does it have trouble shooting section---to check this out while operating is a very very dangerous situation---this better left to a professional do to the machine being able to mutilate or dismember parts of you.
May 31, 2017 | Kenmore HE2 Plus Front Load Washer
LG DLEX7177WM SteamDryer Front Load Electric Dryer, White, 7.3 cu. ft. Ultra Capacity with NeveRust Stainless Steel Drum, 5 Temperature Levels, 5 Drying Levels, 9 Programs, TrueSteam Generator Produces Real Steam, SteamFresh CycReduces Wrinkles and Odor Logo
129 people viewed this question
Top LG Dryers Experts
John Tripp
John Tripp
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a LG Dryer Expert? Answer questions, earn points and help others
