Question about Nuance Computers & Internet
Disabling campatibite mode
It stated the program was running in windows how do I stop it please help
Posted by Lori Ross on
Alex Kagunda
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 197 Answers
Uninstall and install again
Posted on Jan 23, 2014
1helpful
2answers
Running in safe mode as normal start up is really slow or does not load.
Follow this trick to fix infected Laptop:
Disable Unwanted Programs from Running at Windows Startup
Running too many programs at the Windows startup reduces the system performance. To speed up Windows 7, you have to disable the unwanted third-party programs from running at Windows startup.
  • Click Start ' Type MsConfig and press ENTER
  • Click Startup tab.
  • Uncheck the entries of the programs that you do not wish to run at system startup.
  • Click Apply.
  • Do the same for the entries in the Services tab.
  • Click Apply ' OK.
  • Restart the computer when prompted.
To fix this problem instantly use PCFresher system utility.
I have a Samsung NP-RF511 S04AU That won't start past the startup screen. I don't want to lose what is on my C drive can someone please help. I am running Window 7
Several things you can try.
Roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
In Safe Mode try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
1helpful
2answers
Windows 7 task services are all disabled how can I restore them plse
go to the control panel and find it ..or find setting option to Disk Defragmenter it fast
I am not able to install any antivirus in my pc.what to so ?
First, let's see if you can download and run your Anti-Virus Program in Safe Mode. Safe Mode is a diagnostic feature built into Windows to help diagnose problems - particularly problems encountered at startup. When you start windows in Safe Mode, Windows loads only the programs and files necessary to start and run Windows. All unnecessary drivers are not loaded, so certain Windows features may not be available, however, if Windows boots (starts up) in safe mode, you know that your machine is not "brain dead" and you have a basically functional computer.
To start Windows in Safe Mode, start tapping the F8 key as soon as you apply power to your PC. Continue tapping until you se a menu titled "Windows Advanced Options Menu". Using the arrow keys, scroll up until Safe Mode With Networking is highlighted and then press the Enter key. You will see a lot of messages scroll down across your monitor screen. After about a minute you should see a Desktop Dialog box stating "Windows is running in Safe Mode." Click on "Yes" to continue, and Windows will start up in Safe Mode.
Now try to download and run your Anti-Virus program. If it will not load or run, it's because a virus has control of your operating system and is blocking your attemps to remove it. You will have to take your PC to a Computer Technician who will be equipped with the necessary tools and software to remove your virus. Your only other choice is to use your System Restore CD to completely re-format your hard drive and restore your PC to the state it was in when you first got it. NOTE: This will delete all data on your hard drive and you will have to re-install all software programs that you installed on the machine since to first got it.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
After having the computer off for a week, at boot up window washer just sits there and i am unable to run any programs? can you help please?
Try to run ur pc on safe mode, uninstall window washer and try disabling the programs that start with ur pc( run-msconfig-startup-disable all).
2helpful
All my programs on my acer 5520-5537 stopped working.
On boot up, and at the ACER welcome window, press "Alt" + "F10" to see if the laptop goes into the recovery mode.
''WINDOWS DVD MAKER HAS STOPPED WORKING''
The optimal thing to do is remove the software program and re install it. Just as a word of warning if you don't know what services should be starting up with windows you should not disable any. Its fine to disable programs from the start up options, but as a rule of thumb stay away from the services.
Chances are this is a software program problem not computer.
If it still does not work, please post your question more thoroughly. Good Luck.
2answers
I was searching on Google for sermons on abortion. I had gone to several websites when a ''warning'' window opened from my AVG virus protector program. While I was reading the ''options'' as to what I...
try booting into safe mode? on a pc hit F8 repeatedly while you boot until you get a boot screen with the safe mode option. Some laptops have differant keys, eg F2, <Del>, F10, but ussualy they state this when it boots up.
when you get into safe mode, go to your run prompt and type "msconfig" hit enter. got to startup, disable all.Go to services, disable all. reboot. if this works, try running an pdated antivirus scan. I recommend using Avast! which is like AVG. It can do a start up scan. also try running something like 'trojan remover' which is free to download.
Good luck! :)
Laptop will not boot after vrus warning.
Good luck! :)
Program has stopped working
Right click on the game icon, select properties and select the compatibility tab. From there check the "Run this program in compatibility mode for:" box and select Windows XP (Service Pack 2). It might be good to also check "Disable visual themes" and "Disable desktop composition" Hope it helps.
-- WykidTECH
Computers & Internet Logo
Top Nuance Computers & Internet Experts
 Grubhead
Grubhead
ray gallant
Larry Ng
Larry Ng
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
