The machine wont spin or take water its showing error e5h?
SOURCE: e40 fault code zannusi washing machine.
You could look here:
RepairClinic.com (good)
espares.co.uk
AppliancePartsPros.com
Usually located at bottom rear left of washer.
If not there, then located at top front right of washer together with timer control.
SOURCE: error code E 31
The code E31 relates to a problem normally with the pressure switch,heater or maybe the Programmer.The heating element may even check out with a test meter but it can be an earth fault and normally just replacing this part cures the fault.If you are not electrically competant it would be worth getting it checked.
Hope I have helped.
SOURCE: Zanussi washing machine ZWF 14581 error code 43 is
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
