Question about Nokia E71 Smartphone
Connection error in my youtube application error is "could not connect problem with network connection" but other application is running what i do?
  • Padli nurohman Jan 15, 2016
    download patch 2000FBBA and instal.
2 Suggested Answers
Andrew Augustine
  • 102 Answers
SOURCE: i cannot connect to videos using my native youtube application(worked earlier) on nokia E5.Can anyone please assist
first go to application manager, select the youtube app, options and select view access, select data access and choose always allow, select your default access point under connectivity and save, if problem still persist you may have to update your phone.
Posted on Nov 15, 2011
whocareskuma
Dragon kumar
  • 23 Answers
SOURCE: My N8 is recently not connecting to the internet. It shows the following messages when I try to connect it through my AIRTEL connection : Connection failed Connection Unavailable and Network Error -
Bro first delete all the setting from ur cell phone ask for new setting 4m ur operator.after saving settings pls switch off d phone & start it after few seconds and now try connecting to net
Posted on Jan 27, 2012
Hi...! my samsung gts5230w mobile can not play youtube video.. when i clicked a video on youtube, it is connected but not paly the video.. plz help..
did you receive any error message? try updating the youtube application, check your Wi-Fi or data connection make sure you have a strong connections
Sep 18, 2016 | Samsung Cell Phones
Mobil data no longer able to use applications such as email, internet and youtube via mobil networks
Is your data connectivity turned on? also how much data do you have in your monthly data plan, it could have all been used up?
Mar 04, 2013 | Samsung Galaxy Note 2
I cannot connect to videos using my native youtube application(worked earlier) on nokia E5.Can anyone please assist
Nov 13, 2011 | Nokia E5 Cell Phone
How can i unblock my video in youtube
Dear Adel:
Your youtube website is blocked by the network administrator so you do not have the choice but to click the network administrator on the youtube website that says this domain is blocked by opendns. you have to fill it up and write your message and send and wait for the reply. It was blocked by OpenDNS.
Please give me comments if it work.
Regards,
Angel
Feb 08, 2011 | YouTube Videos
Hi,, i hav problem regarding accessing youtube this site was not responding.. when i try to open this site there is a error opening in page,, it wont open so watz the reason behind these, can u assist me...
may be ur internet connection is a slow html connection. youtube requires good internet speed for bufferin videos. otherwise go in network connections and repair ur connection.
Sep 01, 2010 | YouTube Videos
Can't make a wireless connection.
what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
Jun 03, 2010 | Intel Computers & Internet
Network prob.
In opera mini there are two ways of connection [HTTP , SOCKET] . Just try Socket and you'll solve the problem. by the way don't forget to let Applications to run over your connection .
your rating is very important for me , that's why I've helped you
good luck
Jan 15, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Please define default access point first
Default access point is the first method of accesing the internet. It could be ur GPRS connection or the WiFi connection or whatever you have. Once the default fails for whatever reason, it will ask for other methods other than the default.
Apr 25, 2009 | Nokia E61i Cellular Phone
Internet explorer won't open
when it says connected it means to the router, open up internet explorer>tools>internet options>connections tab and tick never dial a connection, or if it's already greyed out it's ok.
Assuming you have run the wireless network connection wizard first to set up the connection, if not it's in network connections and select new wireless connection or set up a wireless network.
Sep 24, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Computer problem
You should make sure that you have administrative previlges to do this.
Some programs may have prevented the network service from being disabled.
This can also be caused by a virus too. So you also install and run a full system scan. Don't rely on a single antivirus. try different one if one doesn't solve the problem.
Some worms prevent the networked systems to be controlled by users of the administrative groups.
also remember that most of today's networks are equipped and monitored with network monotoring ultilities. some of these also acts as firewalls too. This may prevent you from disabling the local area connection.
If nothing works at all, just pull the network plug (RJ45). will disable the network connection. this way the appliaction that is using the connection is likely to display some error message. if this is a freindly application change the configuration settings of this application so that you could control the lan connections.
Oct 29, 2007 | Computers & Internet
Nokia E71 Smartphone Logo
1,306 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
