Amana SXD524VW Side by Side Refrigerator Logo
Zachary Barton Posted on Jan 23, 2014
Amana water filter - Amana SXD524VW Side by Side Refrigerator
brent_joh408
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jan 23, 2014
brent_joh408
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
2012
Points
18
Put bipass plug in filter and buy inline filter
1helpful
Where is water filter located on amana fridg sxd22s2w, made in 1995/6 ?
Your model does not have a filter. You will have to add an inline water filter before supplying water to the refrigerator if you would like it to be filtered.
How do I replace the water filter in Amana sbde522vw
Amana Water Filters Refrigerator Water Filters
Scroll down the above page. Instructions are further down. Video is on the left.
I have an Amana side by side refrigerator model ASD2522WRB06. I replaced the filter that is located in the grill at the bottom of the fridge. Now water does not flow at all.
It should work with the filter removed because of a automatic bypass built into Amana refrigerators but sometimes even new filters or copy cat filters will not work at all because they have a defective area where they connect to your water system.
http://appliance911seabreeze.com/
Why is my filtered water dispenser not working on my Amana refrigerator?
Could be cloged filter problem and filter should be replaced every six months or sooner depend on your water quality
Were is the water filter on a amana sxde 526 m does it have one
I looked up your Model with both P#'s. Sadly no water filters for your Refrigerator. Amana only has a few models with water filters.
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
3helpful
Where is the water filter on the amana #scd25tw
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
3answers
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Amana ACD2234HRS replacement water filter
Don, I have a manufacturers part number of 67003591, you might be able to cross reference that. Straight from the manual..Catriver.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
