SOURCE: automatic shutdown
You either have two issues . The heatsink Fan needs replaced ( it will shut down to save you from burning out the chip ) Or possibly the power supply has an issue . More than likely is the Fan for CPU .
Please make sure you mark my correct solution for your motherboard
Thank you
SOURCE: pc run ok.Os ok,no Virus, Problem when turn it shutdwon it become restart
You can change the pc from the dealer where you have bought. Since you have used only 2-3 days your computer can be replaced.
SOURCE: The computer shutdown and I tried to turn on and
If you are getting through the bios before it shuts down, you may want to make sure that the CPU cooling fan is working and that there is plenty of airflow around the CPU heat sink. Make sure the reset and power buttons are working properly as well. Check that all of your RAM modules and any add on cards are seated properly as well.
Testimonial: "Well I haven't tried that solution yet,but it sounds logical.Thanks tflet"
SOURCE: automatic restart boot
It is either stuck on the install process or you picked up a virus that was going around a while back. Run Virus check from a boot disk if you weren't installing Windows. If you where installing windows, format the drive and reinstall something glitched. You could try removing the file Firststart from the Main Directory but that rarely works.
SOURCE: - mainboard asus p5kpl-cm do
Try updating BIOS and Intel Chipset
http://www.asus.com/product.aspx?P_ID=6nnVb6RBxd7PhGmt
