Thermador SMW272 Electric Double Oven Logo
A
Anonymous Posted on Jan 22, 2014
Need control knob #411363 for model CT227N03 oven
Lakeland Appliance Service
Level 2:
Champion:
  • Thermador Expert 323 Answers
  • Posted on Feb 03, 2015
Thermador Expert
Level 2:
Champion:
Answers
323
Questions
Helped
135357
Points
432
NLA no longer available. try ebay every month
1helpful
Just moved and have diplomat built in single elec oven checked inside but cant find model or serial no. 2 knobs on left all symbols gone some push buttons middle and knob on right numbered 1 to 5
Hello -
Please double check for the model number. It will probably be on a small metal plaque on an edge of the oven door, along the outer edge of the oven opening, or in the oven interior. It could also be on the top of the oven and covered by cabinetry.
Undo the screws that hold the oven in and slide it out 6 inches. You may then find the metal plaque on the top of the oven. You may need the help of another person when you try to pull the oven out, so that the oven does not tilt forward and fall to the floor.
You MAY be able to identify your model of Diplomat oven from one of the images of Diplomat oven control panels here:
https://manuall.co.uk/diplomat-select-620-oven/
Page 6 (PDF document image 7). Note: Use the + icon to enlarge the image.
You may find the image of Diplomat oven knob markings here helpful:
https://www.ukwhitegoods.co.uk/forums/forum/public-support-forums/help-and-support/cooker-and-oven-forum/61498-diplomat-adp4890
Scroll down that page to the post dated 14-12-14 from pslewis333 to see the image.
Once you know which model of Diplomat oven you have, you may be able to find and purchase decals with the proper knob markings for your oven so that you can affix the decals around your oven knobs. Or, you could use heat resistant paint and a small, pointed paint brush to paint the markings on your oven. With either option, I suggest you seal the markings with a heat resistant clear sealant so that cleaning / scrubbing will not erase the markings.
Best wishes.
Jan 24, 2019 • Ovens
My electric oven & broiler elements are not heating up when the they are turned on. kenmore model # 790.94422300
IF it is a electronic control look at the control panel when u turn it on see if it is flashing a F12 IF IT IS YOUR CONTROL IS NOT WORKING may need to call an appliance guy if its a clock style stove with a couple of knobs u turn for the time u may be in manual mode push the knob in to put it back on automatic also check your fuses
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
2helpful
Takes long to reach it's temperature
Hello there
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
1helpful
Hi..if i set the control knob to 350 for the oven..its goes to 400 or 450 degress..i put a oven termonater in there..its always hotter than what u set it on. model # JBP24G0K2AD or the o is a 0 not sure..
The oven thermostst needs replacing, as it is not sensing the correct temperature, this is the switch behind the control knob
Please rate my solution.
Thanks.
Nov 10, 2009 • GE Ovens
GE electric oven will not shut off
You need a part number WB21X5267 Fairly easy to install and worth the effort.
NOTE: sometimes the knob slips on these stoves. So check that you do not have a stripped/loose knob and order the control.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2009 • Ovens
Need instruction manual for operating Indesit Automatic Oven
I have a indesit oven and not sure what model it is because i have no manual, its silver, has 3 control knobs and six small under the small digital screen, it has 1 door at the top which is blacked out cannot see through and the bottom door is clear glass, any ideas?
Mar 02, 2009 • Ovens
Frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
Dec 13, 2008 • Ovens
Top Thermador Ovens Experts
ZJ Limited
ZJ Limited
vince
john h
Are you a Thermador Oven Expert? Answer questions, earn points and help others
