Saeco Vienna Plus - only had it 30 days. Was working great. All of a sudden - no water or steam coming out of wand. It tries, but then after some soft "clunking," the red light comes on. No changes to settings. Wand is not blocked. The water did not run low. She just decided not to work. Is there something simple I'm not thinking of? :-(
do you hear the pump running when you ask for water or steam? You should hear the pump continuously when you ask for hot water, and intermittently when the steam is dispensed.
No hot water or no steam could come from many causes:
valve not working or not actuated (control board), and also the switch that closes when the water knob is turned may be defective.
Do you hear that switch clicking when you open the water knob?
Difficult to help further with so little behaviour information.
Good luck,
M.
SOURCE: Clogged Saeco Vienna de Luxe
Grinder sound like it is grinding to fine. Increase the grinder size. Remember to only change grinder setting when the grinder is spinning. Hope this helps!
SOURCE: Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
SOURCE: No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
SOURCE: Grinds beans, won't dispense water sometimes
I just had this problem. I took apart the brew chamber and cleaned under the screens and everything else I could get to along the path of the water. These areas were completely filled with gum residue and solids. I'm guessing that when they dry out, the water can pass through for a little bit. After a cup or two, they go back to blocking off the water flow.
SOURCE: Saeco Spidem Villa not dispencing water or steam. Need Help!
mine just wont heat up... no hot water.. have only had it for a week... what can i do?
Your steam wand is probably clogged with milk. Remove the panarello outside and stick a paper clip up the tube. Then try to run water out of the steam wand.
Hope this helps!
johnny
