I've changed the belt and it keeps coming off when I try to vacuum
SOURCE: I changed the belt on
Sometimes it can depend on the quality of the belt - if its brand new then it shouldn't snap the moment it is changed; if its an older belt sometimes they can break up the moment they're changed. Ensure that the model you have is correct with the correct product code of the drive belt. Also Check that the sides of the brush bar are not clogged with dirt - one way to check would be to check the brush bar rolls freely with no belt on it before putting a new one on. Another issue is something my old LG upright used to do - it used to break new belts even when the roller brush was completely clear - and the only way to get it to stop was to replace the heavy dirt bag with a new one. It seems the slightest bit of strain on a motor can make things like belts break. Hope all this info helps.
SOURCE: Changing the belt
It is quite easy. Just take off the bottom of the vacuum encasing the roller brush. It should snap off or you may have to unscrew some screws and lift the cover off. Then remove the roller and clean it while you have it out. Now put the new belt on the motor shaft or pulley and slip the brush into the belt. Then replace the roller brush pulling the belt tight. Replace the cover and clean house.
SOURCE: brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
SOURCE: The belt on my vacuum
I would guess you aren't centering the belt correctly, thus it's edge is caught between the brush and another solid object, causing the breakage.
When you get the belt on the the brush and the brush back in place, turn the brush a few times by hand to make sure it's not catching on anything. After you get the powerhead put back together, do this again. It's a common problem if the powerhead isn't assembled correctly.
Here's a video clip from the Bissell site demonstrating changing the belt.
http://www.bissell.com/how-to-videos/replace-brush-belt-vacuums/
