Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
I changed the ntfs format in my 250gb cannot play in my sony tv
2 Related Answers
fwadley
Farren Wadley
  • 482 Answers
SOURCE: hi there
you need to set the partions first
then format
Posted on Nov 27, 2007
Anonymous
  • 358 Answers
SOURCE: Reformat my external drive to NTFS
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Hope this helps you out.
Posted on Jul 15, 2009
2answers
How can I view content on my flash drive, on tv . I can't access the file when I plug in the usb stick
It is very likely that your TV doesn't support files what you have on the stick. Can you access files on computer? If answer is yes then your stick is working. If that is the case check your TV manual for file types supported by TV and also for file system format for memory stick (FAT 16, FAT32 NTFS....?). You may have to change format of your USB stick or recover your files to format recognized by tv. For example tv may read pictures in *.jpg format but not in *.png.
1helpful
NTFS and most of Video formats not supported
Maybe mp4 will ok.I suggest you try kigo video converter ultimate for mac. It can convert almost all popular video formats.
When I connect my Iomega Ego Portable Hard Drive to my Iomega ScreenPlay TV link Director Edition, I can see the files, but I can't play anyone of them: the ScreenPlay TV waits for minutes (trying to...
try to change the format of the portable hard drive, i believe you have it under ExFat, and a usb is Fat32 these options are under any windows platform, connect your device, right click and select FORMAT, here change it from ExFat to either Fat32 or NTFS, the difference between the 2 is simple, Fat32 is more compatible to devices, like car stereos, tvs, etc, but it has a limit of uploading a single file up to 3gb were NTFS doesn't have a limit but not many devices support it. Formatting your drive to another one requieres all media to be deleted, and when your formatting, never forget to select "QUICK FORMAT"
hope this helps!!
I have a 250GB WD drive and it's working fine when connected to PC, but it doesn't show up when it's connected to TV... I tried it with a 500GB Seagate Portable drive and it's working fine in my TV......
Make sure that the File system of the HDD is not NTFS if it is then that could be the problem as NTFS is a format supported by windows and not many external hardware support it directly.
You can see the file system you have formatted it with by right clicking on the drive and selecting properties. You have to format the drive with FAT 32 to ensure better compatibility.
1helpful
How can I format my Screenplay Director?
Formatting the Data Partition
The data partition on the ScreenPlay Director is formatted with an NTFS file system and will appear as a read-only volume under Mac OS X unless special software is installed on the Mac. If you need to transfer files to the ScreenPlay Director by direct USB connection on a Mac, you must reformat the data partition to FAT32 (see instructions below).
NOTE: On a network connection, Mac OS will see the ScreenPlay Director as a shared SMB volume. This means you can use the network to copy files from a Mac to the ScreenPlay Director without changing the format from NTFS to FAT32. (Recommended if available.)
If you reformat the ScreenPlay Director data partition for use with a Windows PC, it is recommended that you use the Windows format utility to reformat with NTFS. Right click on the drive letter for the data partition and select Format.
CAUTION!
  • Do NOT change the partitioning on the ScreenPlay Director as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition can be viewed or played on a TV.
  • Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
1helpful
How can i make my WD passport fat 32 compatible
  • By default Windows Operating System follow NTFS Format and NTFS based File Managers support FAT32 format without any additional changes.
  • Fat32 is also accessible in Linux Operating System without any modification whatsoever
New HDD 250GB installed in PLaystation 3
Hi mate I read my nephew's booklet, apparently you have to go on the internet and download a program from the Sony website and write it on a cd, then you run the cd inside the ps3 and it should format the cd and load the system files on it.
Alternatively if you are not prepared to wait 20hrs for it to format, pop it into a computer with SATA compatibility and format it FAT32 (not NTFS your PS3 will not be able to access it), you will be able to save all your games and mp3 and videos on your new hardrive.
Formatted (on PC) 1TB WD hard drive cannot be altered on Macbook
What OS are you running? What is it formatted as FAT32 or NTFS and how big are the partitions. Various operating systems, hardware and formatting schemes have different limitations. If you want to use the drive in Leopard formatted with NTFS which is the only way to create partitions larger than 20 or 30 GB you may need to install an NTFS file system driver like FUSE.
The other option is to format it as HFS and install Macdrive 7 in Windows to use Mac formatted drives in Windows.
Hope this helps.
Top Western Digital Computers & Internet Experts
Marvin
Marvin
Mike
Mehandi Husain ...
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
