Anyone have a part number or a supply source
SOURCE: TECHNICS SL-B280 DUST COVER W/ HINGES
All parts are discontinued for this model. The SL1200MK2 dust cover will not fit this turntable. You can actually have a dust cover made rather simply and cheaply (depending on where you live). Just take the dimensions to a PLEXIGLASS or even a GLASS shop. You can even purchase the Plexiglass yourself, cut it, and glue it together. I would suggest getting it professionally done. You can use any high impact plexiglass. Get something that is resistant to scratches and discoloring.
- DJ PRO LAB
www.DJPROLAB.com
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
SOURCE: what all can I attach a turntable ground wire to?
Connecting to another piece of equipment besides the mixer introduces the possibility of creating a ground loop, which, of course, is not desirable.
Just make a splice using Stakons (crimper). Just cut off the existing
connector and crimp a (red) round crimp to the existing ground wire.
Then take a length of same gauge and crimp a round a (red) spade Stakon on the other end. Then take a nut and bolt and connect the 2 round connectors and tape with good black tape (Scotch 33 or similar). That will get you through the Gig.
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
SOURCE: Technics SL-BD22 ground wire does not reduce hum. Any solutions?
I have found out that the female phono plugs on the turntable are sensative and have to have a solid connection and often adjusted from time to time to eliminate the 60 cycle hum.
