Question about Samsung SCX 4521F All-In-One Laser Printer
Cru fuse error - Samsung SCX 4521F All-In-One Laser Printer
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: have a cru fuse eror?
Your description is not clear. Replacing a fuse does not repairs the fuser. But if you replaced the whole fuser with a brand new one (not refurbished) then you have a bad power supply board. Unfortunately, you need to get a new copier.
Posted on May 29, 2008
Anonymous
SOURCE: CRU Fuse Error
xeregtei bna aa nadad ogooch pls
Posted on Nov 07, 2008
Anonymous
SOURCE: CRU fuse error , the machine is not working.
I'm guessing that it''s remanufactured?
There is a small fuse on the front of the cartridge that may have not been replaced (or not installed at all). This is required to reset the toner unit - it basically blows at installation.
You can try this -it applies to another similar model, but may work for your as well to reset manually:
Press "Menu"....1934 (you may have to press "#" before the number??)
display will read something like "Tech mode"
Keep pressing "Menu" until displays "new cartridge"
Then press "yes", or "ok" or whatever applies to reset.
Please rate me
Posted on Mar 31, 2009
Anonymous
SOURCE: Cru fuse error on samsung scx 4521f
i changed fuse 4521F , but : (cru fuse error) ???
Posted on Apr 14, 2010
hattinghbr
Rudi hattingh
  • 214 Answers
SOURCE: samsung scx-4521f cru fuse error
Remove the fuse on the cartridge.
Posted on Dec 19, 2011
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Feb 12, 2010 | Samsung SCX 4521F All-In-One Laser Printer
CRU Fuse error
The CRU is a customer replaceable unit such as toner and drum. New ones have fuses that tell the machine that it's new. When they are installed for the first time, the fuse blows and resets the counter.
Jul 18, 2009 | Ricoh AC104 All-In-One Laser Printer
CRU Fuse Error
Sep 30, 2008 | Samsung ML-2510 Laser Printer
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
CRU Fuse Error
you need to replace the toner cartridge and or the fuse on the toner cartridge
http://www.websitetoolbox.com/mb/copierquestions
Apr 16, 2008 | Ricoh AC104 All-In-One Laser Printer
Have a cru fuse error
Rick and Felix are discussing the fuser, not the fuse error you are getting with the your printer. The error relates to a small fuse that is on the toner cartridge which goes into the printer. I am having a similar error message after getting a replacement from Cartridge World (although this is not the first Cartridge World replacement for this printer).
After much research, one suggestion was to remove the cartridge fuse and reinsert the toner cartridge. That worked for me and the CFU Fuse Error message disappeared for me, but I am trying to find out the PURPOSE of having a fuse on the toner cartridge itself. To protect the toner cartridge? Protect the printer? Other?
Mar 10, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
