The only thing I did between firing is put a chamber lock on ot and when I removed it and tried to fire it , it will chamber a round but will not **** or fire , do not believe I have done anything else to it , not sure what it could be please think about and get back woth me thanks . With regards david.my email is [email protected]
SOURCE: How to determine the model and serial number of a marlin 22 rifle?
this is copied from a site, the web address is pasted below.
The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
also if you find serial # you may find more info here.
http://oldguns.net/sn_php/marlinlookup.php
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
