Question about XM Radio (XMP6000)
No sound pioneer airware xm2go radio
Posted by olino portanova on
teyronm
    New Friend:
  • 26 Answers
Did you check wires from the xm antenna to the receiver???//
Posted on Jan 26, 2014
Testimonial: "I did, ended up buying new radio Onyx ez on sale.Thank you for helping though."
  • teyronm Jan 26, 2014
    Did u check your wiring from the receiver to xm antenna... or the positioning of the antenna. try to work on it where the antenna has no obstructions.... Basically u can see the sky,,lol I know it sounds funny, but that way if its working you will get the best reception
I cannot find a home docking station for my Pioneer Airware radio. Do you have any suggestions other than E-Bay? Thanks.
http://parts.pioneerelectronics.com/part.asp?productNum=XMTSE-XMPIH-01
$53.50 retail from pioneer. Any XM2GO dock should work, there are a few home docks on ebay now. You may need to modify it so it can fit your radio, but the pins are all the same.
Dec 28, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Won't power up
have you tried resetting the device....
may be there is some problem in the power circuit
May 14, 2008 | Pioneer AirWave XM2Go Satellite Radio...
I would like to connect my antenna directly to my XM2GO unit without the docking station. Where can I find an adapter?
Simple. Go to http://xmfanstore.com , click on "Antennas and Extensions" under "Shop Categories" on the left most side of the site; there you will find "XMFanStore XM2go Direct Connect Antenna Adapter" .
It plugs into the SIDE antenna port of your XM unit and you plug the antenna into that.
This URL MAY be a shortcut:
http://store.xmfanstore.com/directconnect.html
May 27, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Does this device charge using a usb cord?
No, you cannot charge the AirWave with a USB, you CAN charge a SkyFi3 only with a USB, but the AirWave (all XM2Go clones) require a 5Volt 2000ma (2A) power supply either a 'wall wart' or cigarette lighter plug.
Jan 12, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Turn on fm transmitter for Pioneer Inno XM2GO
Have you gotten it fixed? You did have it in a car dock, right?
Aug 18, 2009 | Pioneer XM2go Inno Satellite Radio...
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
Pioneer Inno shows loading
Not any more help here than with Pioneer. Not sure satellite radio is the way to go if you have to replace the radio very couple of years!
Sep 02, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer xm2go power surge
I have the same problem with my XM2Go. The screen is blank. I ordered a replacement battery but it still doesn't work.
I could really use some help.
Vince
Mar 18, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Xm2go
It occured to me after plugging it into the car adapter and turning on the car ignition. I ended up sending the unit to Panasonic and they sent me another. This must be a known issue.
Aug 10, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
