Televison & Video Logo
A
Anonymous Posted on Nov 17, 2017
I have toshiba model CT-90325 . When i type in a channel number such as 25. It goes to a different channel such as maybe 27 or 42. Sometimes when i use the up arrow channel key, it will go in order for a few channels, then go to a channel 10 or so below. What is going on? Its only a couple months old .
Larry
Level 3:
  • Toshiba Master 5,042 Answers
  • Posted on Nov 18, 2017
Larry
Toshiba Master
Level 3:
Answers
5042
Questions
Helped
1239518
Points
18413
I may stand to be corrected here but I don't believe auto scan has anything to do with directly inputting in a channel such as 25, it should go to that channel even if nothing is in autoscan.... If you have a universal remote like is used on a cable or dish box I would program that to your TV and see if it works ok, and if it doesn't its the remote if it does its in the remote sensor board...Good luck!
The Wyzzyrd
Level 2:
  • Expert 108 Answers
The Wyzzyrd
Expert
Level 2:
Answers
108
Questions
0
Helped
29930
Points
255
Hello... It sounds like you need to run a channel scan. If you have the owners manual, it should walk you through how to do that. I searched online for one, but couldn't find one. I seem to remember something like "Terrestrial" for Auto-programming channels. I hope this helps!
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jul 30, 2006
SOURCE: Concierge series 25" wont stay on channel 3
You have to have the original remote. Then go into the menu under channel set-up. punch in channel 3 press add. The punch in channl 52. then press delete. Or turn on the cable box and go to auto tunnin g and let it do its thing. Im sorry , but if you dont have the original remote with a menu button your going to have to live with your problem. Good Luck
Simpson Neal
  • 236 Answers
  • Posted on Sep 09, 2007
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Anonymous
  • 556 Answers
  • Posted on Oct 06, 2007
SOURCE: No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Anonymous
  • 102 Answers
  • Posted on Jan 15, 2008
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Anonymous
  • 84 Answers
  • Posted on Feb 03, 2008
SOURCE: I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Can a toshiba ct-90325 remote be programmed for other TVs?
No it can't. All that type are single set.
Google
make model replacement remote
they cost about $20.
How do I get this remote to sync to my Toshiba Tv
Just managed to see the model number!
Toshiba CT-90325 Remote Instruction Manuals and Codes.
www.directutor.com > remotes > Toshiba_CT-90325_R...
The Toshiba CT-90325 full-function or Universal remote control to operate varios devices and you can program the remote control to operate most of the popular brands of audio/video equipment like a TV, a DVD player (or VCR), or a Network satellite receiver.
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
How do i enter codes on a toshiba ct-90325
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
How do I program a Toshiba CT-90325 remote
How to Program Toshiba Remote Control
don't forget a thanks if it helps, not that I've come to expect it on here...
I need the codes for a toshiba tv model 26av600a
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2805204&rpn=undefined&modelFilter=40E200U1&selCategory=2797337&selFamily=2838040#
Page 49
The CT-90325 remote is not actually a universal. It's made to control certain DVD players through the HDMI port with something called REGZA-LINK. If you have said DVD player the link provided above and corresponding page number should be the answer you are hoping to get.
1helpful
Toshiba ct-90325 remote will not work
I seemingly had the same problem, it just wouldn't turn on the tv or do anything for that matter so I popped the controller open to have a look and noticed that there was a small square box capacitor where the "cheap" metal that was making contacts with the circuit board had broken so I re-soldered the broken pieces and voila it worked. Cheers I hoped this helps some of you that have this same problem.
3helpful
How do i Program the toshiba ct-90325 remote control to my toshiba dvd player .
Page 49
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
