Question about Motorola Xpr6550 Vhf 136-174mhz 160 Channel
Xpr 6550 no mic audio - Motorola Xpr6550 Vhf 136-174mhz 160 Channel
Randy Reynard
    Master:
  • 623 Answers
Be sure the level is set correctly in the CPS software for your codeplug.
Posted on Jan 22, 2015
I bought a motorola xpr 6550 fr. Ebay and I can not connect with my two existing radio with the same model?
It is a business band radio, not a consumer radio. It must be programmed by a Licensed Two Way radio shop. The radios are programmed by a dealer for whatever frequencies (channels) the customer requires, so each radio can be programmed differently.
Feb 16, 2018 | Motorola Radio Communications
I need to wire external speakers to a Motorola XPR 4350
usually when buying a 2way radio they come with a headset (a headphone and a mic) all you need to do is cut the mic and headphone off using the wires for the headphone solder them to a speaker.
(the higher the power of the speaker the more it will drain your battery)
Mar 22, 2011 | Motorola Talkabout SX900R Two Way Radio
Mastercraft maximum rotary tool icd display is flashing a lock in locked postion
Those digital dremel's are touchy when the get hard use. learn to use it without the display or try to return it regardless if it spins, it's fine.
Oct 21, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
I have a collet nut that will not loosen. at one point while turning the shaft lock button pops up; even when pressed
Sorry, but I seem to have ( essentially ) the same problem... no positive lock. holding the button down while rotating the shaft to find the "best hold" then applying extra pressure sometimes helps. I had no problem with an older model. 400 XPR also seems to overhheat badly.
My ultimate solution: purchasing the model 4000.
Apr 25, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
400 XPR - I am trying to remove a saw attachment. The housing cap is completely loosened, but the attachment won't budge. There is no room to use the wrench to9 attempt to loosen it. I have checked the...
The attachment is 'keyed to the motor assembly so it will only go on in one direction. If it was mistakingly forced on in a different manner it can get jammed. Try twisting it from left to right while pulling straight out.
Jan 13, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
Jul 09, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Motorola Xpr6550 Vhf 136-174mhz 160 Channel Logo
118 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
