SOURCE: Need forward & reverse plastic key buttons
Spray some contact cleaner into the buttons and this may free them up. try this
SOURCE: my paper shredder powers on, but the blades dont
Look for a wadd of paper jammed up in the blades, it don;t take much to plug them up you can over look this very easely. DFD
SOURCE: the shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
SOURCE: Shredder stops when paper put in
Solution: called customer support, who said "It's broken.? But, it was still under warrantee, so I sent it back for a new one.
SOURCE: I have an Embassy shredder,
sounds like one of the drive belts have broke thats all but you will have to take it apart to find the problem
