Question about Proscan 42LA30H 42 in. LCD Television
Volume rises on its own
Volume climbs automatically when powered on to highest level when turned downed it repeats
Posted by Jim Kennedy on
shaun taylor
  • Proscan Master
  • 1,527 Answers
Hi make sure it's not set up on avl go into the menu scroll down to sound settings select avl to off;hope it works
regards
shaun
Posted on Jan 25, 2014
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
Aug 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
Volume maxes out. when poered on
hi go into menu on the tv scroll down to sound setting look for avl set it to off hope it works
regards
shaun
Jan 22, 2014 | Proscan 42LA30H 42 in. LCD Television
Volume automatically goes to the loudest
There should be a setting that allows you to set the "Power On" volume level. Check the menu Under Volume settings.
What is the make and model of the Television set?
Nov 22, 2012 | RCA Televison & Video
I have an audiovox dv7300 surround sound. When i turn the device on, the volume automatically climbs up to 50 which is the max. The volume knob will not bring the volume back down and the remote can bring...
1) retight the springs contacts batteries with pliers for a better contacts
2) open the r.control and clean the keypads very well from dirty, oxide, and bad contacts, with contacts cleaner.
3) otherwise you must go to the repair shop TV.
God bless you
Jul 09, 2012 | Televison & Video
2002 isuzu trooper looses power on climbing, not responding to acceleration
Is the transmission dropping down to lower gear when climbing ? (automatic only ) Will it accelerate good to pass on level road?
Proper fuel pressure, and possible exhaust restriction, such as partially plugged/plugged catalytic converter, are 2 things I would check as well. All provided engine is also in good shape to begin with.
Apr 09, 2012 | 2002 Isuzu Trooper
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
I have a Samsung HCL552W projection that wont turn on.
I have the same tv.. Does the power light even try to come on? or do you hear clicking sounds? let me know maybe i can help u out
Apr 26, 2009 | Samsung HCL552W 55" Rear Projection...
Proscan 42LA30H 42 in. LCD Television Logo
55 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
