SOURCE: car brake lights won t turn off when car is shut down 1996 Honda Odyssey
It should be your brake light switch. There is a little plate welded to the arm of the pedal that has a hole with a rubber stopper. The rubber stopper is most likely missing, or damaged. You should be able to take a flashlight and see the plate and the switch. If the hole is plugged up, you will need the brake light switch, if not, replace the plug.
