It came with the Volkwagon Polo
SOURCE: blaupunkt cancun cr63 car radio
I'm having the exact same symptoms and have had the same luck online. My guess is that the logic got fried during the "brown out" while trying to crank the engine on a very low battery. I thought I might find something about the "VF" and "SK" modes that it is getting into (pretty cool if I weren't missing my radio stations). I'm guessing they are European bands or something. Also getting into a CD changer mode - funny since this was a pretty low-end cassette tape model. My Cancun is 12 years old. What I'm going to try (when it stops raining) is to disconnect the battery leads for 15 minutes or so and then reconnect to see if that clears out the radio memory (if I could easily identify the correct fuse, that would make the process much easier but, alas, I can't). Let me know if you have tried anything else and I'll let you know if my attempt works.
SOURCE: vw beta car radio, made by blaupunkt
To switch the system on, push the button left. When blue background light appears with the word "Safe" en ter your code. Example: code is 3527 push button nr1 3x, button2 5x, button3 2x and button4 7x. Confirm by pushing button 8 or 9. When the correct code is entered the system will go in operational mode. If the incorrect code is entered "Safe" will appear again. Good luck.
SOURCE: BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
SOURCE: lost my radio manual but have code
Blaupunkt Boston CC-22 Code Entry
Turn on the radio, the display will show 'COD'
Press preset [ 1 ] repeatedly for the first digit followed by [ station + ]
Press preset [ 2 ] repeatedly for the second digit followed by [ station + ]
Press preset [ 3 ] repeatedly for the third digit followed by [ station + ]
Press preset [ 4 ] repeatedly for the fourth digit followed by [ station + ]
Finally press the [ station + ] button to save.
SOURCE: laguna blaupunkt radio locked
To unlock it , leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
It could be up to 24 hours...but normally only an hour or two.
