Question about Fisher and Paykel DEGX1 Electric Dryer
Where is it?
Exactly how do I find the reset button on my DEGX1?
Posted by koalas on
  • Anonymous Nov 07, 2007
    Shut the power off
    you have to remove the front panel to reset the thermostat.
    open the lid, remove the (2) outboard front white beauty caps.
    remove the (2) phillips screws under the caps.
    pull the entire top section up.
    remove the (2) horizontal screws at the top front cover.
    pull the front cover towards you .
    the thermostat will be in the lower right of center.
    push the red button and you should have heat.
Anonymous
The reset solution posted on Nov 7 worked for me!
Posted on Nov 20, 2007
Fisher paykel dryer resets repeatedly
this indicates it is getting too hot try running without vent attached if it runs ok it is a pluged or crushed vent
Nov 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
DEGX1 making a clicking noise & mild vibration
Sounds to me like a frayed belt.
www.manualslib.com/manual/889801/Fisher-And-Paykel-Smartload-Degx1.html?page=15#manual
Apr 02, 2017 | Fisher and Paykel DEGX1 Electric Dryer
Dryer does not dry, looking for the reset button. Where is the button and how do i get to it?
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Oct 07, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
Jan 22, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer run but no heat
Try pushing the reset button located inside the dryer housing. (Remove top, then outer housing 'wrap around', reset button is behind the outer 'wrap around' metal in the front of the dryer.)
Jan 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
327 people viewed this question
Top Fisher and Paykel Dryers Experts
Nathan Van Boven
Nathan Van Boven
Bill Eager
Dennis Boxerman
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
