We currently have about 12 BPR40 type radios, majority of which are done for. I bought 4 of the RDM2080D to replace my old with, and was curious if they could pair with the BPR40's until I am able to upgrade them all?
An expert that got 20 achievements.
An expert that got 10 achievements.
An expert that got 5 achievements.
Motorola Master
Re:
If your BPR40s are VHF (model number beginning AAH84K), the answer is yes. The BPR40s can be reprogrammed to match your new RDM2080D VHF MURS radios. This can be done by an authorized Motorola dealer with a current software subscription. (If you cannot find a dealer, look us up online, we will be happy to assist.)
You might want to consider keeping your BPR40s around. The BPR40 has a more economical battery replacement cost (under $35), and is repairable/recondition. (currently $69 flat rate)
Your BPR40s are also capable of more wattage than the RDM2080, 5 watts vs. 2 watts. However, it should be noted the BPR40s will need to be programmed to the lower wattage when going to the MURS frequencies.
The BPR40 is a dealer programmable radio. The frequencies would need to be read out using Motorola proprietary software. The only thing you can tell from looking at the radio is whether it is VHF or UHF. Model number AAH84K... is VHF and AAH84R... is UHF.
Best regards.
The BPR40 is only programmable by Motorola proprietary software. The easiest method for programming them to match one another would be to take them to a dealer. Prices vary, so you might want to call around and price check your area dealers.
If your BPR40 radios are all about the same age, it could be a sign of your batteries getting old and needing replaced. A bad or weak battery will cause the radio to exhibit static, and then eventually poor or no transmit. Check your battery date code first, it is a 3 digit number on the battery label, followed by a space and then usually a number 1. On the 3-digit code, the first number is the year, the next two the week of the year. 229 would be 2012 the 29th week. Replacement batteries should be available for around $35.
If you feel the battery is not the issue, you may have ONE radio which is causing the problem. Try using all your radios and testing by shutting off just one radio at a time. You may identify the culprit. Motorola offers a one year warranty on the BPR40, after the warranty is done, flat rate repair is typically available for $69.
Third possible cause is some type of interference in your area. If this is the case, your radios may need a PL code programmed into them, if you don't already have one. This will filter out unwanted noise or transmissions. Sidenote: If you've added any new computers or electronic office equipment recently, it may also interfere. Some foreign produced computers will lack the filters required in the USA to prevent interference with communications. Coiling excess cables can be helpful in stopping RF noise.
The second of static at the end of your transmission is called "white tail" and is common in all modern radios. There is a programming feature to eliminate most of the white tail noise, it is called reverse burst. Your radio dealer can reprogram your radios and add this to your radios, or future radios you buy. The trade-off with reverse burst is that you will loose the last of your spoken words if you do not hold your PTT an extra moment, as reverse burst actually transmits back or cuts off the end of a transmission to eliminate the noise. White tail is worse when mixing old model and new model radios together.
Here are some troubleshooting ideas:
1) Clean your battery contacts with a pencil eraser, both on the radio and the charger (gently).
2) Have your radio turned off when placed on the charger.
3) Does the light on the charger come on when you place the battery on the charger?
4) Try another battery on the same charger and see if it will charge a different battery.
5) Try the known good battery on this radio and see if the radio functions correctly with a known good battery.
6) Try a different charger with the questionable battery and see if you can get it to charge.
7) Be certain the insert in the BPR40 charger is turned the correct direction for the type of battery you have. When inserted correctly the rails should guide the radio into place, placing the external charge contacts on the radio against the charge contacts of the charger.
8) Check the date code on your battery, if more than 2 years old, replace it.
A couple of thoughts:
1) Check the mic hole and see if it is covered or clogged with debris.
2) Does your PTT button seem hard or the opposite, mushy? You could have an internal PTT issue. The PTT is a common failure part on 2-way radios. Feel around for the 'sweet' spot and see if you can make a simple or partial transmission, or if it will even momentarily open up the receiver on the other unit. If so, your radio is in need of repair. It would likely need a new internal PTT. (At most repair centers where the BPR40 is repaired the flat rate repair currently are around $69 for the BPR40)
3) Has any reprogramming been recently done on the radio? If so, double check the programming to be sure your PL/DPL code is set the same as your other radio.\
4) Check your battery. Trade batteries with the other unit and see if the problem changes. It takes more energy to transmit than to receive.
At our repair shop we use a very mld cleaner that we get at a local "dollar" store. I think because it is so cheap it isn't strong enough to hurt anything. We spray them from afar with a light mist and then use a old toothbrush to scrub tough areas.
Michael
The majority of radios are the DIN type so read the solution below.
If yours is not the DIN type, find your instructions here (under the MAKE of CAR )
http://www.fitaudio.com/
If you require removal keys, then the cheapest place is usually Ebay =====================================================
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Here is a video
showing how to remove a standard radio from the dashboard. A pair of extractors
are required (available from Ebay , Halfords
) but these can be made from 2 pieces of bent, wire coat-hanger or 4
small drills(using the blunt end) or 4 small Allen Keys or 4 small
screwdrivers or 4 nails or even 4 darts. An assistant is
useful to pull the radio out whilst you are releasing the 4securing clips http://www.youtube.com/watch?v=urC-4NbXvDQ note: on some radios
, these 4 holes are protected by 4 small screws. Thesecan be unscrewed
using the appropriate size of Allen key. ====================================================
