Hi, I already have a Sony DAV-DZ840 (1000 W) DVD home theater system. Some how I am not much happy with the sound after hearing Yamaha amps performance. I want to know if I can attach the Yamaha amplifier to my Sony home theater system and will it make a significant difference in the performance?
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
SOURCE: I recently bought a RX-V465 receiver and I need to
1 - As you already have it, take it out of the box and look at the back. You should be able to determine the connections from there. It is also in the owners manual.
2 - The receiver only supports 6 and 8 ohm speakers. Do not use 3 ohm speakers with it.
3 - The Yamaha website has instructions on how to check the firmware version and instruction on how to upgrade the firmware.
SOURCE: hi, i have a problem
My amplifier turns off after 5 seconds, what should I do to fix this problem
SOURCE: How to connect the PS3 to RX-V365 to get best
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
SOURCE: 14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
Register and download the manual for free at
retrevo.com75 views
Any suggessions pls?
