Question about Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD)
I have this seagate momentus hard drive, i had windows home buitin and then i upgraded to 8, after that i formatted my reserved and recovery parttion as i wanted a clean intallation and now i cant see my drives anymore, it just ask for to load driver, what should i do?
Dayton Computer
    Master:
  • 669 Answers
First off....8 is not an upgrade, Win 10 is an upgrade.
Forget looking for any data from your old hard drive as it has been written over and you cannot retrieve it any longer. Just obtain a copy of Windows Ten or pay for a new updated disc. Let Windows format the hard drive and install itself for you.
Posted on Feb 08, 2018
5 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: Laptop can't detect seagate 200GB External Hard Drive 7200 rpm?
Is that external hdd???
Posted on Mar 13, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: Which USB enclosure for Seagate U6 Model ST360020A (60GB)
Hi and welcome to FixYa,
Would suggest a multiple to 1 adapter that would accommodate most if not all types of connection. The price difference would be negligible and since its multiple would work on just about any IDE, SATA, 2.5 or 3.5. A good example is this model.
Good luck and thank you for using FixYa.
Posted on Feb 08, 2009
Anonymous
  • 39 Answers
SOURCE: SEAGATE DRIVER ISSUE
It is a internal hard drive, which connects through IDE cable (the wide one), so you shouldn't be asked for drivers. If in any case you can't see this drive in your "My Computer" ("Computer" on Vista) it's probably because you have connected it wrong. Notice that the end of the IDE cable must be connected tou your main hard drive (where OS is instaled). If Seagate ST340015A is your main hard drive, than the end of the cable should be connected to it. If not, than on the same cable, about in the middle is another connection, you should use that one.
Posted on Mar 17, 2009
Anonymous
SOURCE: External Hard Drive I/O Error
Somehow i tried to format and it was formatted. took pretty long time as 1 terabyte. i thought all is ok as the drive was accessible. Just to double check, i scanned the drive thorugh the seagate manager and it got stuck on 10% for few seconds and then said that the hard disk is faulty and should be immediately returned if under warranty. and to confirm it also gave me read errors http://www.dtidata.com/resourcecenter/2007/05/15/how-to-tell-hard-drive-physical-damage/
so i'm giving it to seagate service centre as it probably has physical faults, bad sectors. and someone told me that 1TB hard drives are not stable.
Posted on Jun 19, 2009
PCTechOnline
Circe Denyer
  • 532 Answers
SOURCE: how to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Posted on Jun 18, 2010
Firmware update
Hmm, specialised disk data recovery person needed here www.data365.com.au
Dec 12, 2013 | Seagate Momentus 54006 ST9320325AS 320 GB...
Seagate momentus 5400.6 drivers download
if it is broken thenit will not take drivers anyway .
Apr 21, 2013 | Seagate Momentus 5400.6 (ST9250315AS) 250...
Seagate Momentus 500GB hard drive on a Dell Latitude laptop running Windows XP with an Excel spreadsheet open. I went away for about 20 minutes, came back and unlocked the user and then blue screen with...
This is a typical hard drive failure scenario, please check if your computer has valid contract if so get your hard drive replaced.
If you have valuable data in your hard drive and willing to spend you can go for hard driver data recovery which is an expensive process.
Jan 04, 2011 | Seagate Momentus 5400.3 Hard Drive
Whats the biggest ram I can put in my HP G7000 note book to replace ST9120822AS which is currently in my machine.
Currently the largest drives for notebooks are are
Hitachi Travelstar 5K500 500GB
Seagate ST9500420AS Momentus 7200.4 500GB
Seagate ST9500420ASG Momentus 7200.4 500GB
Seagate ST9500325AS Momentus 5400.6 500GB
Samsung Spinpoint M7 500GB
Samsung SpinPoint M6 500GB
Nov 13, 2009 | Seagate Momentus 5400.3 ST9120822AS 120 GB...
Formatting seagate hard drive #5400.3
reformat is automatic then it will divide ur hd then install os
Aug 13, 2009 | Seagate Momentus 5400.3 Hard Drive
I need the driver for your momentus 5400.2 hard drive
U have install all drivers properly in ur hard drive it can be work properly
Jul 11, 2009 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Hard disk problem
you may try formating into a linux partion first using partion magic and then to any of the windows partition
Jan 18, 2009 | Seagate 40GB EE25 5400.2 Ruggedized PATA...
Seagate momentus 3 60gb problem
What software did you use for the cloning?
Ghost is the preferred method.
Be sure to choose a disk to disk clone, not a partition clone.
It sounds like you may have created a 20G partition and left 40G unallocated.
Partition Magic may also take care of the problem, if you have access to a copy.
Oct 16, 2007 | Seagate Momentus 5400.3 Hard Drive
Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD) Logo
123 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
