Is there a reset button
Make sure the dryer is plugged into the outlet.
Make sure the dryer door is completely shut
Make sure the breaker has been tripped ( look at your electrical panel )
After checking all of those try it again.
If no luck pull the power cord out of the outlet
remove the front cover and check the door limit switch. should be a normal closed switch meaning that the switch will make continuity when it is depressed. if the switch is good I'm thinking the motor has failed. Mine did this and I replaced the motor and it's been running every since.
