Question about Westinghouse LTV-19w6 Television
Only d-sub works, no tv, side video, or video component cords working
Ive used this tv as my laptop monitor like 98% of the time. It was working fine though and I could switch between both just fine. Now I cant get a video or audio from tv, s-video, and video. Used multiple cable and component cords
5 Related Answers
mpservices
  • 191 Answers
SOURCE: hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Posted on Nov 27, 2008
Anonymous
  • 117 Answers
SOURCE: My Westinghouse LTV 19w3 is not giving a picture
tuner might be bust
Posted on Apr 18, 2010
alpug
Danilo Baraquiel
  • 1961 Answers
SOURCE: I have an older Westinghouse
examine the power supply of your tv a defective/bulge capacitors can cause this problem replace it with the same value.you can easily identify a defective capacitor they appear bulging deformed and melting.you have to open the back cover of your tv to access the power supply this is were the power cord is connected.thanks and please post a message if you have further question..if my solution solve your problem please do click the thumbs up button for my rating..
Posted on Sep 07, 2010
Anonymous
  • 473 Answers
SOURCE: TV works fine, DVD works
Possibility Video Board input Dammage, Cause Bad Solderring Betwen Connector Check IF board for Bad Connection Posibility Capacitor, Filter issue
Posted on Sep 22, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: My audio stopped working for some odd reason. It
Let verify first to narrow down to where the problem can be. First, make sure the MUTE or SAP function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Posted on Dec 07, 2010
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
My USB Ports on the monitor have stopped working
Try replacing the usb cable from the monitor to the computer with a new one or make sure that the cable is connected.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 14, 2018 | Dell SP2009W 20 in. TV
Connecting latop to tv?
use s-video cable  a little round plug most newer tvs have s-video imput that is standard resulution
May 22, 2009 | Dell Inspiron 2200 Notebook
Black and White Video input
Check your plug that plug into computer, one of the legs has bend.
Jan 13, 2009 | Samsung T220HD LCD Monitor
NAD T753 s-video in, component video out problem
I have the same amp. You have to have the same input as you do output for video...ie: s-video in/s-video out, composite video in/composite video out. I know it sucks but thats how NAD designed it.
Dec 01, 2008 | NAD T753 Receiver
LCD Tv doesnot recieve signal from apple computer
try and borrow an adapter from a friend and see if it works. :)
Nov 05, 2008 | Apple MacBook Pro Laptop Computer with...
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Westinghouse LTV-19w6 Television Logo
Top Westinghouse Televison & Video Experts
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
