When you remove a Fob Battery, the system needs to be Reset / Re-Paired using a scan tool computer. They cost around 5 grand USD so only auto electricians or alarm installers, or auto locksmiths buy them and learn how to use them
1. Service it
2. Switch on ignition but don't start engine
3. Press Down Brake pedal and Throttle pedal fully, and hold till service light flashes this may take up to a minute, but usually about 15 seconds
4. Switch off igniton
Hi
I know from experience that you cannot really re synch these fobs on the LDV Maxus vans.
What actually is the fault is an onboard component on the pcb has failed and we normally just replace that with a new one..the fob will be tested for operation and sent back. OR its the Relay in the ESA unit - under the left hand front glovebox on the bulkhead - black with cables going into it. We have those relays (soldered to the pcb) we can supply those or do the work for you. The fob connects to that ESA and the unit then fires the relays to open/close the doors. Sometimes that unit is installed upside down which causes water (condensation) to enter the box and have fun with your electrics.
The fob is SYNCHED to this unit via coding we can use your old fob to clone to a new fob and that will work with the ESA and the vehicle.
We have the parts on this link Items for sale from remobilise ltd
Here is a link to how to program the fob to the vehicle via the programmer - NOTE how you MUST have a working fob to program another (text at the start of the video... LDV Maxus flv
We can fix most problems on the LDV Maxus that occur with faults to do with the Central locking/fobs/ESA/ETACS - three relays are in the ESA and they control ONLY the central locking - two more relays are in the ETACS unit (behind the ashtray) and they control the fogs and intermittant wipers.
Any help or info needed please contact [email protected]
or tel 01792 896404.
Sometimes portable DVD players allow you to switch to a secondary TV for playback. When this happens it disables the primary screen on the portable DVD player.
Thats usually the culprit as to why that happens.
If you have that feature on your portable DVD player you should check it out.
That ribbon cable is a tedious repair, and the best you can hope for is that you are a fairly good tech yourself, or to send it off for repair...accordianman
