Question about Dell PowerEdge 840 (becwmk1_2) Server
I cannot get the Dell PowerEdge 840 to recongize and of my HDD in the Raid array.. Trying to install the OS but tells my on HDD is detected
Cory Kielion
    Sergeant:
    Novelist:
  • 143 Answers
Then you need to get into the BIOS of the PERC RAID controller and inspect the state of the physical/logical volumes. Reboot the machine and watch for the prompt after the PERC5/6 RAID controller loads it's BIOS.
Considering this a null issue given the age, though...
Posted on Jun 13, 2015
2 Related Answers
Q4SteveB
  • 159 Answers
SOURCE: problem with creating array
Ctrl M during power up ..
Posted on Nov 29, 2008
ded_ch
ded_ch
  • 12 Answers
SOURCE: Dell poweredge t110 Raid 5
In a RAID 5 config, you need at least 3 drives (you can have more however). A small part of every drive is then reserved for recovery data for the other drives. So two drives together hold all the data needed to restore a 3rd drive.
The Raid Controllers in the Dell Poweredge Servers are hot swappable. So you can just pull the faulty disk and then insert a new replacement drive in the same slot (Needs to be the same type and size or bigger. However, if the disk is bigger than the other 2, then only the size of the two other disks will be used on the new drive). The Raid controller will then see that there is a new disk and automatically start the recovery process. You will be able to see this when you open the Controller software. Once the recovery is done, the RAID 5 will be fully functional again.
While one of the disks is faulty or missing the two remaining disks will continue to work, but at the severely degraded performance. After the rebuild the performance will be back to the way it was before.
The rebuild can take more than an hour, depending on the disk sizes used.
There is also an option on some Controllers to select one drive as a "spare". Then you insert one more disk and set it as spare. It will not start working unless one of the other disks in the Raid fails. That's when it is used automatically as a replacement.
Posted on May 02, 2011
Disk 4 "is not ready"
> it does detect it on controller initiation.
Even when the drive is not spinning, it will identify itself (manufacturer, capacity) when queried. So, it's possible that it "checks-in", but files/directories on it cannot be read.
Apr 04, 2015 | Dell PowerEdge 2600 Server
Need to increase the hdd size in a dell poweredge 1600sc with raid 1
You will not be able to increase the hdd size of a raid array, it's size is set. If you need more storage, you can add additional drives ( either in raid or standalone ) and use the new drive(s) for storage, but the original array will remain unchanged. The other option is to back up all of your data, install new drives and create a new array.
Feb 10, 2011 | Dell PowerEdge 1600SC Server
Windows 2008 r2. cannot find SAS HDD during install. I have tried to use drivers from Delll official site. But it doesn't help.
What RAID controller are you using? Also, you must first configure RAID in CTRL-C (SAS 5/6) or CTRL-R (PERC 5/6) before even loading the driver will help.
Mar 18, 2010 | Dell PowerEdge 2950 (becwfk1_6) Server
The Dell 2950 Server we have cannot reboot the disc drives
The raid may be fine you need to reinstall the OS.
The best way is to drop the raid array astablish a new raid array then install you new OS on a new raid array.Very nice server you have.
Oct 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Regarding Adding Higher Configuaration HDD Into Exisisting Raid 5
In raid 5 yes you can, yet you won't use the ful hard drive, the system will take only 73GB because that's the smallest HD in your array.
Just, of course, follow the indications for your specific RAID hardware/software about how to add a new HD to it:
http://support.dell.com/support/edocs/software/svradmin/1.9/en/stormgmt/cntrls.html
Mar 20, 2009 | Dell PowerEdge 6600...
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
Poweredge 1600sc cant see other 4 drives
HI thanks for reply. i must say im new to this raid stuff. i was given the server by my coworker because he could not get the other drive to show in windows. he got fustrated and gave it to me. so i tey at home. ok here is what i have.
Dell poweredge 1600sc. it has two gig ram. I open the case andther it has one primary hdd and four other hdd connected on one ribbon to the board. it had windows server 2003 all ready on it. I was in the set up (ctrl +m) and i saw the drives say ready. i hit the space bar to set array. after i did that it say i had to initlize it before i reboot. now the drives say online. i boot into windows and the drives are still do not show. am i looking in the right place. i know. im stupid. go ahead and laugh.
plus is there a good place to lean this raid stuff. thanks. nezza
Aug 05, 2008 | Dell PowerEdge 1600SC Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Boot problem
The BIOS is detecting the cdrom but it is not detecting the Bootable cd I have in the CDROM
Nov 07, 2007 | Dell PowerEdge 2600 Server
Dell Poweredge sc1420 and novell
Hello Moshe88, Can you give me your server's Service Tag please, so I can get a look at the hardware spec of the system please? I'll then be able to assist further. Thanks reaxion
Mar 31, 2007 | Dell PowerEdge SC1420 (SC1420MIN) Server
Dell PowerEdge 840 (becwmk1_2) Server Logo
127 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
