Lenovo ThinkPad T410 Notebook Logo
A
Anonymous Posted on Jan 21, 2014
Horizontal lines screen - Lenovo ThinkPad T410 Notebook
Horizontal line on screen
Horizontal lines are almost always caused by a bad panel
In crt colour tv 4to 5 horizontal retrace lines on screen but picture is having on screen in 75% vertically on the right side of the screen what is the fault
The picture shouldbe free of vertical or horizontal lines.
  1. If the lines are present on the TV screen, press the SMARTbutton. on the remote control and select Settings> SUPPORT > Picture Test.
  2. This menu will appear on the test picture. Select whichoption best describes the result you have.
https://www.lg.com/us/support/help-library/horizontal-or-vertical-lines-tv-CT10000020-1387209695776
A single set of horizontal lines could indicate damage, a graphics system failure, or loose internal video cables. Broken signals from cables or graphics hardware creates impurities in reproducing an image on an LCD screen, conditions that often manifest in the form of vertical or horizontal lines of color. https://itstillworks.com/causes-horizontal-lines-lcd-panel-37988.html
3answers
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
1helpful
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
The display of my phone is working but for last 2 days , there are 3 -4 horizontal lines . i dnt knw the reason . i evn tried factory settings but of no use . please provide me with necessary remedy for...
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
15helpful
2answers
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
