Question about BenQ Cameras
BenQ DVM1 stuck in USB Mode
My DV M1 Digital Camcorder is stuck in USB mode. Turning off and on does nothing and no buttons work to reset the camera.
5 Related Answers
silly girl
yoav kleinfeld
  • 513 Answers
SOURCE: camera-video mode
Is the button stuck? can you turn it back to the left position with the still camera icon? does it turn but stays in video mode? If its just a stuck button, put some special electronics lubricant on it(NOT WD 40!!) and try gently turning it, but it might be a better idea to open it up and work on whatevers keeping it stuck, if you dont trust yourself with it then take it to a reapir person or leave it alone - you're better off keeping your little video camera than nothing at all. If the button turns but the mode stays on video, try a reset/ try removing the batteries for 24 hours, then putting back again/ try new batteries/ try a new mem card. If all fails, use the warranty if you have it, or get a repair estimate and decide if its economical for you or not. Good luck
Posted on Apr 11, 2006
Anonymous
  • 4 Answers
SOURCE: LCD showing "remove len cap and press reset button" always
Simple! Read warnings carefully! It said "remove lens cap and press SET button"! So remove the lens cap and then press the SET button (or arrow downward in the four directions button)! You don´t need to RESET anything...
Posted on Oct 16, 2007
Anonymous
SOURCE: Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Posted on Mar 11, 2008
Anonymous
SOURCE: Sony DSC T7 'Access' freeze when switch on camera
try getting a new memory card
Posted on Mar 15, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Posted on May 05, 2009
My Sony Dvcam DCR-HC15E Mini DV Digital Camcorder is not being seen when I plug it into the USB port on my computer. I have downloaded a program called Driver Robot which is supposed to update my computer...
Go to camcorder Menu and enable USB Streaming option.
Computer / Windows will recognize camcorder and will install drivers automatically for further communications.
Thanks.
Sep 18, 2009 | Sony Dvcam DCR-HC15E Mini DV Digital...
Stuck in card mode
Hi a small switch ( card or DV) is responsible for this problem. If you can DIY fix the camera with a new flexiboard include the switch and it will work properly
Regards Rob NL
Apr 15, 2009 | Canon Elura 80 Mini DV Digital Camcorder
Stuck in "pause" mode
Hold the red button down for a couple of seconds on the right side of the camcorder.  Does the pause go away?
Sep 09, 2008 | Canon ZR40 Mini DV Digital Camcorder
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Camcorder not working right
try a diffrent usb port or check ,make sure you have the hard drive space aval.
Jun 29, 2008 | VuPoint DC-ST300-VP Digital Camera
XH-A1 Stuck in Lock Mode?
Take the camcorder apart then press the button inside it because it seems there is a plastic peice broken on the button.
Apr 10, 2008 | Canon XH A1 Mini DV Digital Camcorder
Stuck in "Record Mode."
Take it back to the dealer while you can! Either let them show you how to prevent this or give you a new one.
Jul 06, 2007 | Canon ZR850 Mini DV Digital Camcorder
Can my camcorder work with imovie and if so how do i get my computer to get download my video?
Open iMovie and set it to capture DV. (Click the camera shaped icon opposed to the siscor scissor shape) When you see a blue screen that says (camera connected) and the image pops on screen of image from tape on camcorder set in play mode, you hit the import button and it begins to capture digital movie using DV compression of whatever you have on tape. You should be able to control your camcorder with the video controllers underneath the project window to make selections for the in and outpunts on the tape you wish to capture. Then switch to edit mode by clicking on the scissor button and import the movies you just captured or use them from the clips menu, etc. renedr movie back to tape, if you wish by clicking back and forth from edit mode (scissors) and capture mode (camera silo) and render to and from tape.
Jan 21, 2007 | Canon ZR700 Mini DV Digital Camcorder
Cameras Logo
Top BenQ Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Daniel Dollive
Daniel Dollive
Are you a BenQ Camera Expert? Answer questions, earn points and help others
