Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
A
Anonymous Posted on Jan 21, 2014
Red light blinks 10 times - Panasonic VIERA TH-65PV500 65 in. Plasma Television
ebet
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 05, 2015
ebet
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1367
Points
8
I had the same problem with a Panasonic Viera Plasma TC-P50S3 with 14 flashes. I used an ohm meter tocheck continuity of the boards inside, starting with the power board (power to TV off). Check YouTube for videos on how to do this. The SC card showed a fault (It was reading close to zero ohms on both pins. I could find no one who supplied SC boards and could only find repair kits. Repairing a circuit board is outside of my ability, time and tools. I found a place online to send the SC board in for repairs. $65 plus shipping. I was getting $350 "ballpark" quotes from Panasonic authorized TV repair shops. If none of this works for you, there are TV salvage companies who will pay you some cash and pick up TV from you. You can also sell it on craigslist for salvage parts or part it out separately. The various boards seem to cost around $100 each and you likely have four or five in your TV. At least for my TV, the parts don't seem to be out there, so there is a demand for the salvageable parts.
5 Related Answers
Anonymous
  • Posted on Mar 13, 2009
SOURCE: tv won't power on. only have a red blinking light
try hitting the reset button somewhere on the side / back
gopakumarg43
  • 76851 Answers
  • Posted on Oct 02, 2012
SOURCE: I can't get my panasonic 58pz800u on the red light blinks 10 times
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 880 posts to different brand TVs now.
Count the number of blinks occur at one time very carefully. There is no chance for a 10 blink pattern for this TV.
Anonymous
  • 14553 Answers
  • Posted on Oct 30, 2012
SOURCE: blinks 10 times
Yes, it is going to be most likely the power board or something connected to it----voltages will need to be checked---most authorized Panasonic shops will also know what is bad in advance.
Anonymous
  • 4 Answers
  • Posted on Mar 23, 2013
SOURCE: panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
gopakumarg43
  • 76851 Answers
  • Posted on Jul 11, 2013
SOURCE: No sound, no picture just blinking red light
Its fan SOS board is likely to be faulty. If you wish to get more details, check the site linked here. It has details about blinking codes to Panasonic Plasma TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Sony kp-57xbr10w. Red light blinks 10 times . When you turn power on sound comes on . No picture . Then no sound and red light blinks 10 times . Help
Sounds like a highvoltage failure. might be the flyback or focus circuit too. oddly I cant find any useful info about 10 blinks.
Trying to update my sony kdl55ex621 firmware and now I only get 10 red led light blinks
Congratz. You bricked it. Messing with fimware is mortal for electronic equipment. Maybe an authorized Sony repair service can help you, most probably not.
No picture or sound, red light blinks 10 times
Usually, 10 blinks to LCD TVs denotes a sound processor fault.If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
3helpful
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Panasonic plasma red light blink 10 times
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS.
These are the faulty boards and sections to be checked. Just visit the site named 'Electro-help'. Blinking codes and repair work with Panasonic plasma TVs are described in detail. Check this link, and select the site. Pull up older posts there.
1helpful
2answers
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
2answers
4helpful
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
1helpful
Red light blinks 10 times then 9 but won't turn on.
Can you confirm that the model number of your set is KP46WT520 as I dont want to give you the wrong information.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
