Question about Element Electronics ELCHW261 26 in. TV
I DON'T HAVE THE REMOTE ELCHW261 FOR MY TV. I need to change my setup to antenna, but I do not have the remote to change the setting. Tried a universal remote, did not work. Please help!
Posted by nncy1953 on
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: I do not have the remote that came with the TV. I
you may have to break down and order a remote for it.http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=CC-FLX-32-021 I bought a VCR long time ago without a remote. big mistake. ended up ordering a remote for it it was useless without it
Posted on Dec 07, 2009
Randy Green
SOURCE: I need a Remote foe a 26" Element TV
I have a brand new one....give me an offer on it
[email protected]
Posted on Feb 13, 2010
Anonymous
  • 222 Answers
SOURCE: remote don't work properly
Remove the batteries, open your remote clean the pcb (with cotton ball slightly damped in rubbing alcohol) the one that is painted green as well as the carbon contacts the one behind the remote pads, let it dry and put it back, replace with a new batteries.
Posted on Jun 06, 2010
Chi Chu
  • 8457 Answers
SOURCE: i need a universal remote that will work with this
Try website like Remotes.com to buy the original remote or very colse to the original.Sorry no special universal remotes to any tvs,that what functions you got from the universal remote,that what u get.
Posted on Jun 22, 2010
Anonymous
SOURCE: My 42" full HD Digital
I purchased this same TV, however mine came missing the pedestal stand. Would you be interested in selling your pedestal if you aren't using it?
Thanks
Posted on Oct 19, 2010
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Why is my remote control not working despite changing the batteries.
Not sure if this will help but, I recently put an antenna on the roof of my house. I don't watch TV much but wanted to enjoy some TV, but my remote locked up and the side buttons on the TV wouldn't work either. I tried changing the battery, but no luck. There's a broadcast station 64.2 that is locking up TV's & remotes. Here's the fix that a TV repair co. gave me which did break the lock of the station 64.2.
1) unplug antenna (not roof but connection from TV to wall)
2) unplug and plug back in TV
3) find a way via remote or side buttons to scan channels
4) Go to Menu
5) EZ Setup
6) Channel Set Up-Scan Channels
7) Channel Memory
8) Digital Set Up
9) Turn Skip On for 64.2 (Delete this Channel)
10) Turn off TB
11) Hook Antenna back
You may have to play with the order to acheive the end result or figure out a way to delete 64.2, but during the process you will at least unlock from being stuck on 64.2.
Good Luck if this was the same issue!
Jul 14, 2014 | Audio Players & Recorders
Can't get the tv to switch from cable to antenna mode using a RadioShack remote or the buttons on tv
It sounds that the front panel controls are locked with your tV. You have to unlock it first, if you want to change its input selections. If you cannot select the inputs by using the remote control [I thing you are using a universal remote control], setup the remote control with an other setup code. All codes to remote control won't work with some functions. You have to search and select, which code give maximum functionality with your TV.
Jul 06, 2012 | Zenith SY2569X TV
Turn off widescreen on element elchw261 tv
Select menu in remote control, select format, change ratio size to fit your screen. If you do not know the correct format, you may have to try all the options.
Jul 04, 2012 | Element Electronics ELCHW261 26 in. TV
I have 722 and a ir/uhf remote. Remote is set to uhf. All was ok until about 2 weeks into use and remote does not work unless 6 inches from antenna. I tried wizard numerous times and resetting to ir and...
jholsinger1,
It sounds like this is TV 1 that you are having this problem with the remote, is that correct? What has changed from when the remote was working till now? Was anything moved like the TV/receiver? You may have some type of interference with the UHF signal. Without getting more specific information, I'm generalizing the trouble shooting steps. Would you clarify if it's TV 1 or TV2. Please post to this site and I will respond back to you.
Ray Calo
DISH Network
Jan 16, 2011 | Universal Remote Control DISH Network...
Cable to Antenna Issues
You would need to purchase a universal remote, and once you program the universal you would be able to change from cable to antenna or vice versa.
Although there is a slim chance that in the setup screens on your TV (if you can access them by pushing a button on the tv) would have a selection where you could change the 'input' that is selected. If that is not an option, then it is definitely time for a universal remote.
Jun 23, 2008 | Daewoo DVN-14F6N 13" TV
Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Feb 17, 2008 | Daewoo DVN-14F6N 13" TV
Element Electronics ELCHW261 26 in. TV Logo
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
