Pit SSR 110CC Pro Beginner  Bike Logo
N
Nathan Parsons Posted on Jan 21, 2014
How put a pitbike 12inch rear wheel on - Pit SSR 110CC Pro Beginner Bike
b0nes
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 29, 2014
b0nes
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
5515
Points
6
Buy a 12 Inch rear wheel with the same diameter axle as you ha e and with a centre hub that looks identical. Remove the old axle, remove chain, swap disc tyre and sprocket over then refit
tip
How to bump start a 110cc pitbike or 125cc pitbike
at first push your bike to a hill (dosnt matter how big or small)
remember where you can put it into second gear hold the cluch in and push down the hill and let out the cluch and jump as soon as it bites then it should fire up same as a car but harder on a pit bike as you got too much throttle you will flip it and gotta do it all again haha hope this was helpfull
if it still doesnt fire up then you have a problem with your bike
IMPORTANT........................................................................
1. make sure the petrol is on and the bike isnt flodded
2. make sure not too much throttle or it could be dangerous and if you do flip it lose go straight away
on Dec 06, 2009 • Exercise & Fitness
When I play a record, and the gripper arm is in front the tone arm lands on the wheel and does not land on the 45
Some decks have a selector switch for 7inch and 12inch records. You need to find it and select the 7 setting. However you will need to switch it back to 12 if you want to play an LP.
Over heating pitbike
Make sure oil level and viscosity is proper, clean out the head fins so engine can breath, lose some weight,(your too heavy for the bike), if water cooled? check rad-cooling fluid?
Do you need a back brake on a 110cc pitbike
It'll run without one, but I don't advise it. It adds more braking power and the rear brake is needed in certain situations where using the front brake can be more dangerous, such as slick surfaces. The rear brake can also be used to get the front back down in the event of an unwanted or out of control wheelie.
Jan 21, 2014 • Pit Cycling
Loncin 125 pitbike
The easiest way to tell is to wait until the engine is warm and then put the lever in the opposite position. If the engine struggles, it is in the "choke on" position.
May 15, 2013 • Motorcycles
1helpful
12inch craftsman bandsaw won't turn on
Maybe the bearing are covered with dust . Do a thorough clean up on it . Does it hummmm whenever you attempt to turn it on?
Nov 14, 2012 • Saws
Top Pit Cycling Experts
john h
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Pit Cycling Expert? Answer questions, earn points and help others
