Question about Bose Wave Radio
Bose wave radio flashing
There is power to my Bose Wave Radio (display shows time), but it is not functioning at all. Tried replacing the battery on the little remote, but I still can't get any action. (How do I even know if the remote has become non-functional?) The only other detail is that every ten seconds or so, the time display flashes once. Is there a way to hard-reset the entire unit? Help!
Posted by Randy Benson on
5 Related Answers
jjcicala
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
Anonymous
  • 20 Answers
SOURCE: I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Posted on Dec 31, 2008
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: Bose wave radio won't turn on
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monpoly on repair of these units. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to provide a $200 allowance towards purchase of a new Wave. Before you spend the big bucks on theis trouble-prone product though, you might want to check out the new HD radios -- better sound and MUCH lower prices than Bose.
Posted on May 22, 2009
Anonymous
  • 22 Answers
SOURCE: Bose Wave Radio AWR1 1W
I can tell you what to check if you know how to use an ohmmeter. But I warn you you could get shocked if you do not know what you are doing. The transformer has 3 windings, two are for DC voltages, and the other is 3V AC.Your meter can measure those using the AC scale. Next, check the voltage on the 3 terminal regulator IC. One leg will have 18V, the output will have 10V. Again please use CAUTION! Finally, the to-92 transistor Q1 is used as a 5V regulator. Check it (with power off and unplugged) for any shorts, especially base-emitter. If non of these ideas work, I would offer to buy your non working unit if you decide to get rid of it.
Posted on Jun 30, 2009
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
[email protected]
Nov 30, 2015 | Bose Wave Radio
Bose radio will not turn on
You didn't mention which model of the Wave Radio you have but since you have a 9V battery it narrows it down to a couple of models. You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
May 19, 2010 | Bose Wave Radio
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
Bose Wave unplugged now it won't power up when plugged back in
I will first start check the power section circuitry of your Bose Wave radio. Are you electronics savvy?
Jun 16, 2009 | Bose Wave Radio
Bill B.
Mar 26, 2009 | Bose Wave Radio
No power
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to give owners of broken sets a $200 allowance towards the purchase of a new Wave. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price.
Nov 11, 2008 | Bose & Wave& Music System
Bose Wave Radio
Mar 05, 2007 | Bose Wave Radio
Bose Wave Radio Logo
137 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
