Summit scr1536 has stopped cooling. I hear a ticking noise every one and awhile. The fan is running and sometimes I think I hear the compressor kick on and the off shortly later.
SOURCE: fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
SOURCE: compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
SOURCE: GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Here is the basic idea on how to keep the
refrigerator, air conditioner, or vacuum cleaner to work properly. Air is moved
by an electric fan or blower in order for that product to work properly. If air
movement is blocked the fridge won't get cold, the central air conditioner
won't cool enough, the vacume cleaner won't clean as well. Check on your
fridge's air movement by inspecting the bottom of the fridge for dust and cob
webs. Remove the front bottom clip-on plastic grill. Or also even access the
lower back of the fridge by removeing
the screws holding up the heavy cardboard cover to see inside. Blockage
of air flow will prevent a fridge from getting cold. Just like a vacuum
cleaner stops working when the bag is filled with dust and fibers. The air could be blocked by the accumulation of dust and
fibers. Look under your fridge if it is
cloged, it will look just like the stuff on a dirty central air filter.
Dust and fiber buildup blocking the fridge's air
movement from back to front (or visa-versa) of your fridge will slowly (years)
prevent how good it cools. The build-up of dust and cobwebs prevents your
fridge from cooling (more specifically prevents the heat to disapate
from the metal heat disipating fins
attached to the metal tubes to be blown off by the fans air). OK! Remedy
for a vacuum cleaner REPLACE THE CLOGED VACUUM BAG.
Remedy for your fridge manually REMOVE THE
CLOGING DUST AND FIBERS FROM UNDER YOUR FRIDGE. SORRY fridge
manufacturers do not provide a dust filter like the vacume cleaner and central
air systems manufacturers do. You have to figger out
the best way you can clean it. Possibly vacuum with a crevice tool, or use
a small brush than vacuum. The extreme would be unplug
the fridge ( so you won't get electrocuted) bring
a water hose into the kitchen and spray water at cobweb buildup at the bottom
fridge, than wet vac the floor then wait
20 minutes to dry before pluging the fridge back into the electric outlet.
When you stand in front
of your fridge and you hear the fridge electric motor turn on, the fan will
blow air.The fridge
