How to stop buffering
How do I stop buffering through my internet
Posted by brian smurthwaite on
  • Anonymous Aug 22, 2018
    FYI, there is a new product on the market called the eLektra Booster. It is designed to reduce lag and buffering issues up to 99% of the time. It is currently not available in stores. At this time, it can only be purchased on Amazon.
adam adms
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 829 Answers
  • 1 Allow the movie to load completely, or at least halfway, before you start to watch it to stop video buffering.
  • 2 Start the movie and then hit stop until the movie has fully or halfway loaded. As the movie is loading, you should see a yellow or gray line. The line you see will get longer as it loads.
  • 3 Close all windows that you don't need. Having too many windows open will slow the loading process.
  • 4 Resume play once the movie is at least halfway loaded or fully loaded. By this time, you should be able to enjoy the movie without the video buffering or constant starting and stopping.
Posted on Jan 21, 2014
1helpful
How do I stop youtube from buffering?
Buffering is the process of loading the video from Youtube servers to your screen. The buffering depends mainly on speed of your internet connection. You can try the following options
  1. Switch to a highspeed internet connection
  2. Once the video starts, press the pause button. Leave it for 5-10 min and then try playing
Dec 15, 2014 • Cell Phones
1helpful
My phone keep buffering can you help me.
Hi
When you say your phone keeps buffering, I assume that you are watching, films, or clips on it over the Internet. Buffering s a symptom of an Internet connection that cannot download information fast enough for it to be displayed at normal speed. The playback therefore stops and "buffering" takes place until there is sufficient data on the phone for playback to resume until the next time it needs to stop and buffer the contents. If you cannot get a fast enough data signal, then you need to move around until you get the best signal on mobile broadband that you can.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 13, 2014 • Cell Phones
2helpful
2answers
How do I stop the buffering altogether?
Buffering occurs when you have slower internet connection . Use the link http://www.wikihow.com/Make-YouTube-Stop-Buffering to stop buffering . If you want to increase your internet speed, contact your ISP to upgrade your internet plan and make your youtube videos loads faster .. To check your internet speed gets raised or not by using Scanmyspeed.com
My phone is a 3g phone.It keeps buffering and stopping the movie.Why is that.And can you stop the buffering.Thank You
the buffering depends on your internet connection. all you have to do is to let it buffer the whole video before watching.
Jul 16, 2014 • Cell Phones
PANDORA WONT STOP BUFFERING ON PHILLIPS 3D BLURAY
buffering is always a problem with the internet connection speed
depending on your carrier and the type of connection usually either broadband or dsl that is your problem contact your provider a or use less internet with other devices when using netflix high bandwidth
How to stop movie buffering
Which types of movies buffering stop it you. If you Download file buffering stop then click stop button or not button available then disconnect internet connection or closed it file. Or if you watch movie in PC/laptop then simple stop button used.
Thanks..
Tech Support Mart
2answers
How to stop buffering on galaxy tab 3
I assume you mean video buffering. This is usually caused by a slow internet connection. You have a galaxy tab 3 so I assume the device is not the issue. If your internet connection is improved you should see the buffering happen a lot less. Try measuring your internet connection speed on a website. Something like http://www.speedtest.net can tell you what your internet speed is. Usually you want to be at least 5 Mbps or higher download speed to see minimal buffering issues.
2helpful
3answers
How can I stop the buffering on my high speed internet?
It's not only for You..While watching Videos Online the Internet speed get slow ...Also the Online videos buffer and display in screen..So you can better pause the Video in Youtube after select the video.Then you can see a buffer lines scroll through end.After that You can play it.You can watch it without buffering.You can check the speed of the internet at Scanmyspeed. com here You can check the speed in Mbps and MBps.
1helpful
2answers
How to stop buffering on daily motion and other video sites
Thank you for writing in regard to your buffering issue. Let me help you with this. First,buffering is caused by slow internet connection, there are some tips that you can do to lessen the buffering. First, you may clear your browsers cache and cookies,then lessen the number of tabs or browsers opened. You may als0 consider contacting your internet provider for increase bandwidth.
Computers & Internet Logo
Ekse
