Question about Zapco Reference 200 Car Audio Amplifier
Zapco z300c2 won't power on - Zapco Reference 200 Car Audio Amplifier
Posted by Jesse Krum on
If my zapco amps break down will the company repair them for free
Only if its under warranty. If you are the original owner with a reciept from an authorized dealer then they will warranty it for free. You can find information here---> www.zapco.com/support.html
Feb 11, 2014 | Car Audio & Video
Install my amp
Go to this link and see page 47
http://www.zapco.com/files/Download/DCRef.pdf
Jan 18, 2013 | Zapco Reference 650 Car Audio Amplifier
How many rms does my amp have.....??????
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
May 22, 2011 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
I need a manual for a zapco PEQ 9 band (old school) equalizer. can you help me?
i got a wiring paper that comes with the peq plug,its not a manual but it shows how to wire up a zapco peq
Nov 07, 2010 | Zapco Car Audio & Video
...storing noise detected from my
Storing as in Distortion? If that's the case lower the output gain from your amp until it is suitable to you ears. It might be all the way open, besides this should be adjusted system to system.
May 31, 2010 | Zapco Reference 650 Car Audio Amplifier
What is the wiring orderfor the zapco seq
the basic wirings are for inputs, power and for the speakers (front and rear). If you open up the device and trace the wires to the fader control (electrically), those are for the speaker outputs. The power supply line is much easier to locate through the power capacitor..maybe. watch out for the remote wire if it has one (this triggers the device to power ON). gudluck!
Apr 10, 2009 | Car Audio & Video
Zapco 18 band eq
You will need to call the manufacturer, ZAPCO - 209-577-4268, or email them at tech support [email protected] , in order to purchase the part you are missing. It is possibel to hard wire the RCA parts you need and creat a homemade fix, but in all honesty it is not worth it, and it will probably introduce a lot of interference in to the quality of your signal path rendering it a bad option. Give them a call / email. If they will only sell the part to a dealer, call Car Depot @ 615 - 269-8080 and they can have the part purchased and delivered to you for a small fee. Good luck.
Feb 01, 2008 | Car Audio & Video
Zapco ag 350
Check your ground and make sure it is properly grounded ....it needs to be a very clean paint/gum free area tightly bolted.  Next Check and make sure you are recieving your 12 volts (not running)  13 (running)    by placing your test leads from positive to ground...... then make sure your power remote from your head unit is putting out voltage.
Aug 23, 2007 | Zapco Reference 200 Car Audio Amplifier
ZAPCO 9.0
Go here first http://www.zapco.com/ Good Luck
Aug 06, 2006 | Zapco C2K-9.0XD Car Audio Amplifier
Zapco Reference 200 Car Audio Amplifier Logo
44 people viewed this question
Top Zapco Car Audio & Video Experts
Marvin
Marvin
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
