PROGRAM MY UVERSE REMOTE TO TCL TV
I WOULD LIKE TO PROGRAM MY ATT U-VERSE REMOTE TO MY TCL TV MODEL NUMBER IS L40FHDM11 I CANT FIND A CODE THAT WORKS. THANKS.
Posted by stephanie on
    Top Expert:
  • Televison & ... Master
  • 76,407 Answers
0174,0179,0173,1070. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Posted on Jan 22, 2014
5 Related Answers
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: need a code for att uverse for the remote for
Click Here for the list of Manufacturer's Code for AT&T Uverse
Posted on Jul 27, 2010
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: my att remote control for my uverse did not come with a manuel
Here is the manual for the remote and the codes are there also.
http://helpme.att.net/pdf/uverse/remote_control_user_guide.pdf
Good luck and Please rate FixYa!
Posted on Dec 28, 2008
Anonymous
SOURCE: need remote code for model L32HD41 RCA TV.
A learning remote found at Target works great! It is a universal GE 5 device remote control (model 24950) - and the best thing is that it is under $13! It can only be purchased in the store, but if you go on the Target site, you can check if your local Target has them available.
Posted on Oct 24, 2009
davey_fitzge
davey_fitzge
SOURCE: tcl l40fhdm11
Most RCA Codes Will Work Depending On Your Remote.
Posted on Jun 06, 2012
gopakumarg43
  • 76407 Answers
SOURCE: codes for Magnavox TV wlDVD to work with ATT U-verse remote
Four digit universal remote codes for Magnavox TV are:
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Setup Proceedings.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Posted on Jul 06, 2012
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
Tcl l40fhdm11
Jun 06, 2012 | Universal Remote Control Remote Control
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
Att u-verse remote code for coby tftv1923? not
Here, try this link. It's a rather large pdf, so it may take a little while to open.
https://uma.att.com/assets/files/U-verse_Feature_Guide.pdf
Apr 02, 2010 | Coby TFTV1923 19 in. LCD TV
Att uverse codes/Cisco dvr box
is ipn 330hd the model number for the cisco scientrific atlanta box
Apr 28, 2009 | Televison & Video
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Emerson tv and at&t uverse
Try code 1465. On my Emerson LCD TV the only thing it won't do is turn the TV on -- all other functions are controlled by the AT&T U-Verse remote however.
Jan 21, 2009 | Emerson EWF2704 TV
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
