I've had issues with my computer freezing up lately but other than that it worked fine and then when I tried to turn it on it said "NTLDR is missing. Press CTRL+ALT+DELETE to restart. So I did and it still won't work. What might be the problem and how do I fix it. I haven't downloaded anything.
SOURCE: My Satellite A40/A45 Series won't boot up.
If NTLDR is missing, you will need to do one of two things:
1) follow this link and follow instructions to create a NTLDR boot disc and get back up and running
or
2) boot to Windows CD and repair Windows installation
Hope this helps - remember to rate :)
SOURCE: NTLDR is missing
Check if the solutions on this site work for you "http://www.computerhope.com/issues/ch000465.htm"
SOURCE: i get ntldr is missing on my netbook, help in simpliest of terms
Pressing Ctrl, Alt and Del just restarts the computer.
"ntldr" is a windows boot file which has become corrupt and unreadable causing the computer to loop on boot up.
As far as i know that laptop does not have a CD/DVD drive so you can't fix the problem unless you have a external CD/DVD drive and a recovery CD.
Is the netbook still under warranty? If so take advantage of that and send it in for Acer to deal with.
If not you will need a recovery CD or Windows install disk, an external hard drive and some patience.
If you need anymore help or advice please post back.
Good luck.
SOURCE: mY IBM THINK PAD R51 IS SHOWING ERROR MESSAGES
Make sure there's no floppy or jump drives or cd's in either (happened to me before ;) cut and paste this into your browser it's a cool site. Lot's of reading but really informative. Hope this helps. Good luck and please rate me. Thanks. http://www.computerhope.com/issues/ch000465.htm#b
SOURCE: NTLDR is missing Press Ctrl Alt Del to restart
In my experience, NTLDR is usually caused by a failing hard drive, however sometimes other factors are at fault.
There are various fixes for the different operating systems that Microsoft offers. Since you don't state your operating system I'd say start here and read.
http://www.proposedsolution.com/solutions/ntldr-is-missing-press-ctrl-alt-del-to-restart-2/
Then there's always microsoft's take on it here:
http://support.microsoft.com/kb/320397
