Question about Canon Pixma MP800 All-In-One InkJet Printer
Scanning slides with mp800
My mp800 keeps telling me that it is "adjusting the lamp please don't open the document cover" and it just stays there, the printer doesn't make any noise like its working at all. Please help.
Posted by Grubwess on
Anonymous
    Genius:
  • 2,985 Answers
Try uninstalling the software.
re start the computer and re installing- seems as if there is an incomplete set up.
Posted on Oct 23, 2007
Hi, I have a mp800 cannon printer and for the past few days it either doesn't print part of a document, or on other ocassions it will printer gray lines over everything and lastly the pages have come...
The chances are the printhead is clogged and needs to be soaked overnight in warm distilled water to dissolve the dried ink. Remove the cartridges, use plastic electrical tape to cover the ink outlets to avoid the ink drying, remove the printhead and soak it overnight. (you may have to repeat the soaking if the ink is really dried).
Blot the printhead with a lintfree cloth being careful not to damage the electronics. Reinsert the printhead and test print.
This should clear the problem.
Let me know if you have any other problems or questions
Please make sure to rate this solution. Thanks.
Jul 24, 2011 | Canon Pixma MP800 All-In-One InkJet...
Tip
Canon pixma mp800 Drivers and manual for Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma Mp800 photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture below reads mp730, but the actual page linked will be for MP800 efa9883.jpg
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon Pixma MP800 All-In-One InkJet...
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Canon pixma mp800 manual Pixma MP800 Printing cannot be executed because the lock switch is on. Question where is the lock switch ?? Release the scanner lock? Where is the scanner lock and how can I...
Doesn’t sound like your are making it into service mode, make sure the inner door is all the way up, make sure the top is closed, make sure both feeders have paper in them, make sure to turn off the power but do not unplug it. Start by pressing the stop/reset button first and then power button.
Aug 14, 2010 | Canon Pixma MP800 All-In-One InkJet...
Foutcode 6500 pixma mp800
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .........
Jan 08, 2010 | Canon Pixma MP800 All-In-One InkJet...
Top cover will not remain open
I am not completely familiar with that model of machine, but most doc feeders have an adjusting screw on the hinge to increase the spring pressure Most are accessible from the back, it may be recessed, so you might need a flashlight to locate it. Some require the removal of an inspection cover in the back of the hinge.
If you locate one, adjust it to just hold the feeder in place, too much tension may create a problem with it sitting properly in the down position, and pressure on the belt when feeding.
Hope this is of some help.
Ed
Apr 20, 2009 | Office Equipment & Supplies
Scanning documents
try to adjust properly the before scanning option
make it scan the whole page
if this not help tell me so i can help u further
plaese rate this post
Aug 23, 2008 | Canon Pixma MP800 All-In-One InkJet...
Need help w/Copier on my Canon all in one
hi switch on your printer and place the document on the flatbad at the top of the printer glass and press button black for black & white copies and color for color copies.
Dec 06, 2007 | Canon Pixma MP800 All-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
157 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
