Question about Samsung CLX 6220FX - multifunction fax / copier / printer / scanner color
Samsung CLX-6220-FX vertical lines when scanning and copying
Tim Schattkowsky
    New Friend:
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Posted on May 26, 2015
1 Related Answer
Martin Ryan
  • 18 Answers
SOURCE: Black vertical lines issues on Samsung multifunction fax SF
Black lines are usually a sign that you have toner on the laser slip glass which is usually situated above the drum unit, its just a little bit of glass if u give this a wipe and get toner on ur finger or rag then thats probably what wrong. If you don't I would look at your drum unit as it might not be cleaning correctly, which would mean getting a new one.
Hope you find this info helpful. Cheers
Posted on Dec 13, 2008
Vertical lines when scanning and copying
Had the same problem. Samsung said new machine or circuit board.
I had nothing to loose, so I tried cleaning and remelting solder joints.
You can Google to findout more and make your oun decesion. I sprayed liquid solder flux on the solder side of the board and put in preheated 450" oven for 25min and took it out to cool. Ihas worked fine ever since. I will try again on other boards if I have a similar problem. I fixed a circuit board on the body control module on my Escalade last weekend. I could see the bad joint on this board with careful examination. I used a solder gun this time because I could see the exact spot and it was a larger solder joint.
Hope this helps you. Robert
May 16, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
I got a Samsung CLX 3175 when I scan or copy or vertical lines comes out on the paper. But when I print from the computer it works good.
Hi!
If you lift up the document feeder where you set your documents you will see a thin piece of glass to the left,clean it with a damp cloth and it will be gone!!
Enjoy!!
Jan 14, 2011 | Office Equipment & Supplies
Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
Mar 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN All in One Printer
open the scanning unit. in scanning unit clean the mirrors.
Sep 16, 2008 | Samsung CLX 3160fn All-In-One Printer
I have black vertical lines on copies from automatic feed
Good luck. I've tried everything. The stupid thing jams on me 9 of 10 times so I guess the good news is I don't get a lot of black lines since it won't even print.
Jul 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 6220FX - multifunction  fax / copier / printer / scanner   color Logo
1,440 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
