Question about Canon PIXMA MP130 All-In-One InkJet Printer
Waste ink absorber
Printer tells me absorber is almost full so will not print
Posted by dumbo on
  • 8 more comments
  • Anonymous Nov 23, 2007
    I got the same problem with the same message on both mp110 and mp130. The printer is blocked for any action including those not involving any ink (scanner, ...).
    Many thanks for finding a solution (I was told that I have to remove and disconnect the power supply block until the eeprom is loosing its data). Menu item "NVRAM" has to be reach through a scan-copy-scan button pushing sequence. I need confirmation and/or complementary procedures in order to have an opportunity of success.
    Best regards.
  • rickdixon Dec 06, 2007
    help me with this problem please, i don't know what to do.
    waste ink absorber is almost full on mp130 printer
    thanks
  • Anonymous Feb 09, 2008
    waste ink absorber is full.contact the service center for the replacement of the waste ink absorber. can you help me correct this problem without contacting,the service center.viv
  • Anonymous Feb 23, 2008
    waste ink absorber problem
  • Anonymous Jun 10, 2008
    mine is pixma ip1200. it says ink absorber is full. it's not printing anymore.
    what will i do
  • ossamabin Aug 31, 2008
    Hi, Have the same problem, and have adopted the suggestion in removing the absorber pads & cleaning with alcohol. This has worked great, however after replacing everything back into the original compartment & restarting the printer, the alarm light continues to operate displaying the original message regarding waste ink absorber almost full etc. I am unable to further config via the menu button as this original message overides any further actions I wish to move on to.
    Your help is required for a direction please.
    Cheers
    Paul.
  • Anonymous Aug 31, 2008
    El depósito de tinta de desecho está lleno.
    Póngase en contacto con el centro de servicio para cambiarlo.
  • eurek7 Aug 31, 2008
  • Anonymous Jan 05, 2009
    CANON PIXMA MP 130, ERROR 5100
  • Anonymous Mar 20, 2014
    my printer won't print. Where is the ink absorber and can I fix it
Anonymous
    Scholar:
  • 32 Answers
The waste Ink absorber is a small, deep sponge, located where the cartridges rest when the printer is idle. Although you can technically reset the counter on the amount of ink held in the absorber, if you overfill it, over time you will start to have color staining on your cartridges, since your carts clean up on it after every cycle, at the extreme, you can have ink residue build up under your printer. Online printer supply shops can sell you a replacement absorber cheap.
However, since I am skilled in the art of "frugal" you can also do things this way. You will need some rubber gloves, rubbing alcohol, and a small prying tool.
1) Locate the absorber at the bottom right of the cartridge path
2) With gloves on, pry up the absorber (if you have the almost full warning, be prepared for some good splatter.)
3) In a small dish with a small amount of rubbing alcohol, shake the absorber around for a short while to moisten the outer ink.
4) Rinse the absorber in a metal sink (porcelain can stain) with more alcohol, then leave it to dry.
5) Replace and make sure the absorber is seated the same as when you took it out.
Then you want to reset the counter for the absorber.
1) Enter the Service Menu by keying = Menu,Scan,Copy,Scan.
2) Use the arrows to navigate to Service Menu Counter Access. then press OK.
3) Use the arrows to navigate to ABS-M Dot Count, press Copy.
4) Use the arrows until the count is zero, press OK then Reset.
5) For good measure, turn the printer off and on.
Bada boom! like brand spankin new!
Posted on Jan 08, 2008
Anonymous
Thank you Mighty Falcon for your solution to fixing my Canon Pixma MP130! Last night I got the message that the waste ink absorber was almost full, and after searching around online found your solution, and it worked perfectly! The only thing that took a little more figuring out was which part the absorber was. It was two small rectangular pieces inside of a bigger piece. I just gently pulled them out with my fingernail and they were black. After soaking them in the alcohol, they are now white! And yes, gloves would have been a good idea, as now my fingers are black with ink. But hey - it's worth the cost of having to go get a new printer! THANK YOU!
Posted on Jan 21, 2008
3 Related Answers
Anonymous
SOURCE: canon printer mp160 e27
how can i get my ink absorber to be unful and work agian so i can print again WANALI
Posted on Oct 11, 2008
Anonymous
SOURCE: printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Posted on Nov 12, 2008
Anonymous
SOURCE: ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Posted on Apr 09, 2009
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer won't print. Says to contact service
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
Waste ink absorber almost full. What do I do?
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
May 04, 2009 | Canon I960 InkJet Photo Printer
Printer says ''waste Ink absorber is full'' see service center
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
937 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
