Sony bravia lcd digital color tv
How do you get rid of demo mode (loop). Its so annoying as every time I press return it goes away and them appears on the screen, dominating the tv programme. There are four different displays it brings up. It says left side is motion flow on and Right side is motion off. Then it displays all of its features. Then it says Demo Mode (loop), live colour / On (left side of screen) and Off right side of screen). I cant turn it off. Is my television faulty. I have spent ages trying to fix this problem. Any help would be appreciated. Cheers Janice
Posted by Janice Trevina on
1 Related Answer
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I have a KDL 40V5500
Your TV is stuck in shop / demo mode. To exit this mode you will need to restore the TV to factory defaults then run through the initial setup again. Please follow the instructions below to restore the TV to factory default settings:
1. Press the HOME key on the Sony remote to open the menu / XMB
2. Use the arrow keys to highlight SETTINGS (the toolbox), then SETUP and press the + key (in the centre of the arrows) to enter the SETUP menu
3. Use the DOWN arrow to highlight FACTORY SETTINGS and press the + key
(FACTORY SETTINGS may not be immediately visible in this menu,, so keep pressing the down arrow until you can see it and it's highlighted, then press +). You will be asked to confirm that you want to restore the factory settings.
4. Highlight YES (yellow is the higlight colour) and press the + key
5. If asked to confirm the reset again, highlight OK and press the + key
The TV will now be restored to the factory settings and you will need to run through the initial setup again. Use the arrow keys and the + key to select your LANGUAGE, COUNTRY, then LOCATION. On the location screen, make sure you select HOME - if you select SHOP, the TV will be in demo mode again after completing the setup.
On the AUTO-TUNING screen, you can select SKIP as your stored channels are not deleted during the factory reset.
Hope this helps. Unfortunately, while it's possible to enter shop mode accidentally using the remote control, to exit shop mode, the TV has to be reset. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Apr 14, 2011
My sony tv has a line across the screen that says bx42, full hd1080p, digital noise reduction, usb play, hdmi2, bravia sync, pc input, 24p true cinema and i cant get rid of it.
Hi mike harris,
i think your TV is on demonstration mode.
To turn off the demo mode, press and hold the HOME or MENU button on the TV for more than 10 seconds. The messageDemo mode: Off will appear on the screen.
NOTES:
Mar 02, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Get demo mode (loop) off my Sony TV
Press the home button and hold it will reset to factory setting. This was a in store option to display what is in the TV. Sony told us how to fix it. Press the Home button and hold it for a few seconds.
Dec 27, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The wording "demo mode motion flow" is at the top of the screen and won't go away. how do i get rid of it?
You need to go into the TV menu and turn it off.
Press HOME, then select s_xmbs_set.icon.png > Picture & Display > Picture Adjustments > Motionflow > the desired option.
Good luck and let me know if this helps!
Oct 13, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
How do i get rid of the demo loop on my sony lcd tv
go into your home menu - then into setings and then restore factory settings and reset tv up.
Sep 19, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I got demo mode loop ,how to remove from my tv
i have demo mode showing on top of screen how do u get it off
Aug 30, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Turn demo mode off on Sony Bravia TV
Press and HOLD (5 sec) the MENU button located on the SIDE of the TV. A message will appear; (Demo Mode: OFF).
Mar 30, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
Store Mode is ON.
for Bravia's.. To turn off the demo mode, press and hold the MENU button on the TV for more than 10 seconds. The message Demo mode: Off will appear on the screen.
Let me know if this helps.
Feb 21, 2018 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Televison & Video Logo
241 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
