Question about SanDisk 4GB microSD High Capacity Memory Card
Please insert disk
INSERT DISK
5 Related Answers
Anonymous
  • 50 Answers
SOURCE: San Disk Micro Cruzer 4GB
Try plugging it in to a different USB port on your computer. Make sure the connecter on the Cruzer is clean and there's no dust inside.
Also, try plugging it in on a different computer.
If none of these work,
I'm afraid it's a hardware problem and there's nothing that can be done about that.
Hope I helped!
Tom
Posted on Jun 20, 2009
Anonymous
  • 93 Answers
SOURCE: vista recognizes the disk but wont open anything
try keying in the address of ur removable disk directly onto ur address bar. if not change ur usb port and try again.
Posted on Aug 06, 2009
laikexpert
laikexpert
  • 281 Answers
SOURCE: Insert Last Disk of Multi Volume Compressed File
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Jan 30, 2010
ikkenom
  • 10406 Answers
SOURCE: my memory is connected through card reader in
The "table-of-contents" on the memory-stick has become corrupted.
If you have pictures on that memory-stick that you want to "rescue", search online for "file scavenger" software.
If you think that the memory-card is "empty", put the memory-card back into your camera, and tell your camera to 'FORMAT' the memory-card, i.e., to initialize it back to the "factory" settings.
Posted on Jul 20, 2010
jayatithapa
Jayati Thapa
  • 83 Answers
SOURCE: insert disk error every time
your media may be demaged check creck on its body
Posted on Aug 03, 2010
What's your problem?when i insert into compact disk the give the message please insert disk. please solved my problem..
put other working cds.if working,ur cd is damaged.if other cds are not working,ur cd drive is damaged.contact to ur service provider.
Jun 16, 2012 | Computers & Internet
Have disk in drive E but computer says "Please
try to put some cd lens cleaner if you have a previous cd cleaners you can use it
Aug 03, 2011 | Acer (KV.16X04.007) DVD Drive
Please insert a disk into drive E: my pen drive
hey plz help me out of my pendrive...
1)whenever i insert pendrive the error cums please insert disk it gets detect but it shows this error and i cant open
2)second problem m facing dat my pendrive is not showing me in disk management just ican change a drive letter
3)i did everything by changing drive letter also...
plzz sumone can help me out...
Aug 21, 2010 | Generic Memory USB 2.0 128MB Black Pen...
Dell demension 3100 dvd plays any disk ok but will not burn
when you try to save or burn any data to disk, you should use burning programs just like nero or any other burning program. at the time when you click the button burn, it always ask you to insert disk such as CD/DVD +R or RW
Mar 25, 2010 | Dell Dimension 3100 PC Desktop
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
Disk boot faliure please insert disk and press enter
Sounds like your hard drive has failed and became corrupted or the boot sequence is causing this on the motherboard. I reccommend entering CMOS setup if you can and changing the boot sequence to putting the hard drive first and if that doesn't work insert a recovery disk in during the disk boot failure...please insert disk and press enter screen. Jus make sure to press enter after inserting the disk if that is done...and if that fails I suggest replacing your hard drive with a similar one of equal value and qualities.
Jun 05, 2009 | Intel Motherboard
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Pendrive error message "please insert a disk in removable disk"
right click my computer.
click manage
selest disk management
right click to drive-H
select change path 7 name of drive
change it to any letter except lettur used for your other drives
thats it it is done.
Dec 23, 2008 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Please insert disk H
4GB pendrive detected but when we want to open it shows please insert a disk into disk H:
Aug 09, 2008 | Kingston Technologies 512MB DataTraveler I...
Moser baer 4 GB pen drive is not working
i have 4gb moserbaer pen drive when i inserted it in to the Xp system it give the message "Insert disk"
plz. solve this problem.
Aug 05, 2008 | Computers & Internet
SanDisk 4GB microSD High Capacity Memory Card Logo
32 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
