Question about Printronix Line Matrix P5005B Printer
15v ctl fail see manual - Printronix Line Matrix P5005B Printer
harjindar
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
Logic card have to change
Posted on Jan 07, 2015
2 Related Answers
Anonymous
SOURCE: 15V CTL fail*
+15 Voltage Regulator is sourced on the CMX. Used by Hammer Bank Logic, Ribbon Drive, Shuttle Drive and Paper Feed Drive Logic on CMX.
a) Redownload Flash software.
b) Replace Flash Memory SIMM.
c) Check / Replace Hammer Bank Logic Cable Assy (152421-901).
d) Check / Replace Hammer Bank Power Cable Assy (164805-901
e) Replace the CMX PCBA
Posted on Jun 23, 2010
Anonymous
SOURCE: I purchased line matrix printer
chek your printer smps or connection loos contact
Posted on Mar 15, 2011
My printer shows 15V CTL FAIL. see manual. so the solution
If the Printronix P5010 line printer displays the 15V CTL FAIL message on the screen, use these steps to resolve the issue.
1. When this error code generates on the printer's screen, it might indicate an issue with Ribbon drive (Right), Ribbon drive (Left), +15V Regulator, and Hammer bank Interface.
2. If the issue is with the ribbon drive (Right) & (Left), then do these steps below.
The resistance on the motor should be checked.
To ensure that there are no opens or shorts present in the printer, check the continuity on the Extension cable.
Search for the binding on the motor.
Also, check for the obstacle in the ribbon path which might cause excessive load.
3. If the problem is occured due to the +15V Regulator, then do these steps.
Redownload Flash software and replace Flash Memory SIMM.
Check or Replace Hammer Bank Logic Cable Assy and Hammer Bank Power Cable Assy.
4. If the issue is with the Hammer Bank Interface, then Check or replace Hammer Bank Logic Cable Assy, Hammer Bank Power Cable Assy, and the Shuttle Frame Assy. Call Our Toll-Free 1-866-293-9220
Sep 27, 2018 | The Office Equipment & Supplies
15v ctl fail assy
Bad main board. Get the number off the board as there are 2 different kinds.
Sep 16, 2013 | Printronix LineJetĀ® P7210 Printer
Problem with Printronix psa3 P7210 Printer 15V CTL fail*
Sounds like your controller board is bad but would need some more information from you. Like controller board part# with version #. email or contact me back. [email protected]
Mar 20, 2013 | Printronix Line Matrix P5005B Printer
15V CTL fail*
Jun 21, 2010 | Printronix Line Matrix P5005B Printer
My IBM 6400 comes up with the error 086 Controller 15V fault on power up and therefore fails to get to the 'ready' state. Please advise on diagnosis of fault
The manual recommends replacing the hammer bank logic cable even if there is no damage to cable seen. You might do the cable shorts test recommended on page 263 of service manual
Oct 13, 2009 | IBM 6400 Matrix Printer
Cruise control can not set speed but cruise ctl light is on
Sometimes the plastic cog on the side of the throttle body (TB) breaks. This cog is "pulled" by the cruise control accuator's cable.
To check, simply look on the side of the TB and check to see of the cable end has broken free. (The mechanisim is much like the brake cable on a bike)
Apr 16, 2009 | 2000 Acura TL
15 Volt CTL fail
Hi Serap,
If a fault condition occurs in the printer, the status indicator on the control panel flashes on and off, and the message display indicates the specific fault.
For the operator-correctable faults, After correcting the displayed fault, press the CLEAR key to clear the error message and status indicator and resume printing. If the fault message reappears, contact your authorized service representative.
If a fault is not correctable by the operator, you may try two steps to clear the fault before calling your authorized service representative:
1. Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required.
2. If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required. If the message reappears, call your authorized service representative at 1-800-243-3338.
Message Explanation Action 15V CTL FAIL* Controller voltage failure. Contact authorized service representative.
Call 1-800-243-3338
As far as software for the flash file is concerned , I have checked with their officaial sites , but they donot have any firmware updates.
Thanks
Mar 27, 2009 | Printronix Line Matrix P5010 Printer
Printronix P5209 or Proline 5 Series
when printer powering on, printer gives message "15V CTL FAILED SEE MANUAL"
May 15, 2008 | Printronix Line Matrix P5005B Printer
Printronix Line Matrix P5005B Printer Logo
408 people viewed this question
Top Printronix Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Harrie
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
