Question about LG LRSC26920TT Side by Side Refrigerator
Icemaker After my icetray dumps the ice it does not level out when it returns to ice making position so the water shoots out in the freezer and only partially fills tray. Not sure what to do to make the tray level properly. Thanks for any help.
Posted by facemaker on
  • facemaker Oct 24, 2007
    No answer yet. I have cleaned out the ice container. The problem seems to be that the tray doesn't properly level when it returns to be refilled. Anxious for a solution.
Anonymous
  • 92 Answers
Unfortunatly you need a new icemaker
Posted on Feb 10, 2008
1 Related Answer
Anonymous
SOURCE: icemaker
did you find out how to fix it ? please let me know
Posted on Sep 01, 2008
The ice maker stopped making ice
There are only three things that could be bad. First thing you need to check is your water shoot. This is the tube that expels water into the icetray. This could be clogged with ice. If so take a hairdryer and defrost the tube. That being said, your inlet valve is going bad. The reason it is freezing up is the inlet valve is leaking water slow enough to freeze the water shoot. This would also give you the sign that your inlet valve is going bad which is located on the back of the refrigerator where your water line is attached. If those are working properly than it is your icemaker. Normally the icemaker itself is not the problem. I hope I helped you.
Sep 02, 2010 | Kenmore 75082 / 75084 / 75089 Bottom...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Samsung RS253BAVQ freezer Keeps defrosting, and wont dump ice
One posibility is that it is not defrosting a all and that the ice is building up on the evaporator coil behind the rear cover inside the freezer. This condition will block the flow of cold air. Remove the back panel to see what your have. Either no ice , light frost, partial icing or heavy icing blocking the fins. Complete light frosting is normal.
Sep 09, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
My ice maker has stopped working water line has water in swicth is on but no ice.
make sure that the compressor is running. on the icetray there is a adjustable setting of how thick the ice must be. make sure that your setting is right. if the setting is right your machine should work.also make sure that the water is running over the icetray.
Aug 07, 2009 | Refrigerators
The ice maker will not work no ice, the fingers are not rotating...I move the switch up to the OFF position and back down to the ON position...still nothing...the water is connected and coming out the...
Hi: The ice maker is on a timer independant of the switch. When you turn it on it will activate the timer only. Not necessarily making ice right away. Also the freezer has to be at zero degrees F to make ice. So it dosn't dump water or slush in the fridge. Set your freezer a notch colder. Be patient and don't do what everybody does and check every hout to see if it made ice. You'll just dump the cold air out of the freezer. Give it 24 hrs. This is the best solution before calling service. I hope this helps, Jeff
Jun 09, 2009 | Refrigerators
Icemaker
Jul 06, 2008 | LG LRSC-26922 Side by Side Refrigerator
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
LG LRSC26920TT Side by Side Refrigerator Logo
308 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
