Televison & Video Logo
Lg flatscreen tv purple
My LG 42" flatscreen (42LN5700) was purchased less than a month ago. I turned it on a few nights ago and had a picture, pulled up the cable guide and was scrolling around, and a couple minutes later went to a purple screen and haven't been able to get a picture since. I can watch DVDs, and my other cable functions are fine (wireless works). I've unplugged/plugged in, tried a different HDMI cable... any other suggestions?
Marvin
    Top Expert:
  • Televison & ... Master
  • 85,241 Answers
Take it back.
Posted on Jul 13, 2017
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: Half of the screen is black and doesn't display the picture
Send it back this appears to be a major failure
Posted on Oct 20, 2007
Anonymous
SOURCE: BRAVIA TV KDL-40V2500
i had the same problem and the only way i could solve it was to disconnect power from the tv, let it "reset" then it would be ok for a bit. the problem went away entirely when the cable company updated its software for its hd box. might be coincidence....
also, pre-update, the resolution wouldnt automatically set correctly. If I turned on the tv to a hi def station, it would set to 480 and only set to 1080 when i changed to a normal station then back to the hd. then it was fine. again, after the update from the cable company this went away.
Posted on Nov 05, 2008
Anonymous
SOURCE: LG TV - TV Guide Function Stuck
I have the same issue on an LG TV. The TV Guide is completely black with a small picture in the corner. It's as if the software is no longer working.
Posted on Jul 31, 2009
Anonymous
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
Anonymous
SOURCE: LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
Posted on Dec 11, 2010
2answers
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Lg50pc1d purple screen
try to unplug the set for a period of time?
I have an LG 50PS8000 plasma tv which is nearly 2 years old. For the last few months its has occassionally been getting a red haze over the entire screen which either dissapeared on its own or went if you...
I've also had a popping noise on our 50" LG plasma TV, however the picture has not gone, but has turned grainy and colors are weird. Can this also be a blown fuse or a more severe problem (ysus board or similar)?
I purchased a 32" flatscreen
A tv this new probably has a warranty. Take it back and let them fix/replace it. It's their headache with the warranty.
I have a LG Plasma Flat screen TV. I purchased it
With seeing the picture it will be hard fro me to tell what..I am going to guess according to the information you've provided.
It could a buffer or a signal board(s). This TV is only 4 Months old I would call LG and file a warranty claim. LG (800) 243-0000
Best of luck
N Sabre
1helpful
We bought an LG flatscreen TV and a digital...
it's the aerial, tv has nothing to do with channels. it's the signal that carries the channels. i'm pretty sure if you had it hooked up to a cable box, you'll get all the channels, so i'm sure your tv is fine. i would double check on the aerial and positioning the attenna has some factor into it.
1helpful
LG DLP Suspected Faulty Bulb... how to be sure?
First pull back off turn TV on watch Fan behind lamp more then likely it is going bad Fixed LG 9months ago and it was the Fan.If Fan Stops turning Lamp will not light.
19'' LG TV, Audio but no Picture - I'm an LG representative
The back light circuits is dead, send to LG fix for free
1helpful
2answers
LG KF510 will not turn on
Take it to the repair shop. My son's KF510 did the same. I await the results of the autopsy!
It started to play up almost straight away when he bought it a month ago. Last night it failed to go past KF510 logo then goes to a low level purple screen. Removing the battery seemed to fix it prior but not now!
Top Televison & Video Experts
Marvin
Marvin
