Question about Epson Office Equipment & Supplies
Unexpected error occurred please restart
1. Prescan works 2. Auto located image 3. Tap Scan 4. Tap OK 5. Get message (Unexpected error occurred. Restart EPSON Scan. 6. Repeated 5 above several times, Shutdown and restarted both Printer and PC Same results from 1. above.
5 Related Answers
Anonymous
SOURCE: HP DIRECTOR
I did an F Disk, and resolved many of my problems
Posted on Aug 01, 2008
Anonymous
SOURCE: ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Posted on Mar 26, 2009
Susan Hall
  • 4 Answers
SOURCE: Minolta Dimage Scan Dual III Problem
Chances are you have a Twain conflict. Unplug all other items that use usb ports. Restart and then see how it goes.
I have not had trouble with this while using my Dimage scan 3 but had horrible problems similar with other scanners...took me forever to understand this.
Hope it helps.
Posted on Jun 26, 2009
trainjunkie
  • 35 Answers
SOURCE: Minolta Scan Dual IV - Error 4 and Error 1
Forget about the Minolta software. It's buggy at best. Use VueScan instead. A free trial is available so you can test it before you commit to buying it. Available for Windows and Mac.
http://www.hamrick.com
Posted on Aug 16, 2009
Anonymous
SOURCE: agfa snapscan e20, winXP unexpected error, application will clos
This means that in the save path there are some not supported symbols. Try saving in c:\ or d:\. This helped me.
Posted on Feb 14, 2011
What is an Ox97 or 0x97 error code on an Epson WF-3640 printer?
Error Code 0x97 in Epson WF- 4630 means there is decrement in efficiency of printer. The printer may be not printing the pages as it used to print earlier. You don't need to worry anymore. You can follow either of the Solution to resolve the Error.
Solution 1:
Step 1: Download "0x97 Fix Patch:
Step 2: Click "Scan" button.
Step 3: Click :Fix" button to repair the Printer.
Solution 2:Step 1: Restart the computer. Login as an administrator user.
Step 2: Click "Start" button> "All Programs"> "Accessories"> "Tools"> "System restore".
Step 3 : Now click "Restore my machine to an earlier date"> "Next".
Step 4: Select most recent system restore date within the "tap a restoration date" Listing and click "Next".
Step 5: Click "Next" on the verification window.
Step 6: Restart your PC is required after the completion of restoration process.
Now, try to work with your printer again.
Call Epson Printer Support Team 1-800-213-8289 if the Error is not resolved or you are having any other kind of issues.
Visit: Epson Printer Support Phone Number 1 800 213 8289 Tech Support
Jul 06, 2017 | Epson Office Equipment & Supplies
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
How do I scan an item and send a copy to a friendI am using a Photosmart C5280 printer
Please follow the steps below to do a clean installation of your scanner.
The first thing we need to do is remove any files that have been installed and start with a fresh installation.
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on CHANGE/REMOVE.
7) Restart your computer.
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your scanner model.
3. Under the Drivers & Downloads section select Windows.(Make sure it is the Epson Scan utility. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
Reinstall
1) Double Click on the Epson1**.exe file that you downloaded to your DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when prompted.
4) Connect the USB cable. Windows will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use.
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
  1. Click OK once settings are changed as desired.
  2. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
  3. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
  4. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
  5. Now you can use them in mail and send to your friend.
Jul 04, 2010 | HP Photosmart C5280 InkJet Printer
How do you enter frequencies for finding standard deviation? For example, Frequency=50, total of X or raw scores = 366.5. Summation of X squared =2836.39. What is standard deviation? How do you enter the...
I am afraid I do not understand. The frequency of a PARTICULAR score is the number of times that particular value occurs in the data. It is not the number of data.
Ex: the data are:
4, 6, 5, 4, 4, 8, 9, 3, 3, 6, 7
Frequency of (3) =2
Frequency of (4)= 3
Frequency of (5) =1
Frequency of (6)= 2
Frequency of (7)=1
Frequency of (8)=1
Frequency of (9)=1
Number of data =11 (n=11)
You compute the mean M
M= (2x3 + 3x4 +1x5 +2x6+1x7+1x8+1x9) /11 =5.363636..
As you can see, if a term is not repeated it is multiplied by 1 (its frequency is one). Value 3 occurs twice (hence 2x3); value 4 occurs 3 times (3x4), etc.
To calculate by hand the sum of squares
3: (3-5.3636)^2 + (3-5.3636)^2 .................... = 2x(3-5.3636)^2
4: (4-5.3636)^2 + (4-5.3636)^2 +(4-5.3636)^2 = 3x(4-5.3636)^2
5: (5-5.3636)^2 ...................................... .= 1x(5-5.3636)^2
6: (6-5.3636)^2 +(6-5.3636)^2......................= 2x(6-5.3636)^2
7: (7-5.3636)^2.......................................... .=1x(7-5.3636)^2
8: (8-5.3636)^2......................................... ..=1x(8-5.3636)^2
9
: (9-5.3636)^2......................................... ..=1x(9-5.3636)^2
If I have not made a mistake the sum of squares is 40.5454
Standard Deviation
The standard formula above gives s= square root (40.5454/10) =2.01
Population Standard Deviation
The population Standard deviation above is S= square root (40.5454/11) =1.9198
So if you perform the calculation with the calculator the only times you need to enter the frequency is for repeated terms. When you have to enter 6 above, its frequency is 2 you proceed as follows
6 [2nd][FRQ] 2 [Sigma+]
Once you entered the raw scores, the calculator does the rest.
Hope it helps.
Nov 06, 2009 | Texas Instruments TI-30XA Calculator
Hp officejet 7310 all-in-one software will not install
  1. Solution one: Make sure the hardware is functioning correctly(try to make a copy)
  2. Solution two: Restart both the All-in-One and the computer
    3. Solution three: Check if the correct scanning device is selected as default under HP Software
    4. Solution four: Download and run the Scan Diagnostic utility(FROM HP.COM)
    5. Solution five : Check that the Digital Imaging Monitor is running
    6. Solution five :Try scanning without HP Imaging software
    7.Solution six :Try scanning without HP Imaging software
Jan 26, 2009 | HP PSC 1410v All-in-One Printer
HP DIRECTOR
Jul 31, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scan copy to computer
Please check the original software disk that accompanied the scanner. You should have the option to install a twain or twain32 driver at the least, which would allow you to scan from within a graphics program (photoshop, or even paint).
Jul 04, 2008 | Epson Perfection 2400 Photo Flatbed...
Epson
I know the error is on the printer but it may still let you scan.
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Jun 06, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
1,345 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
