SOURCE: memory card is locked
There is a small tab (like a very small hole with a sliding piece of plastic) on the corner of the memory card. Slide it to unlock it :)
SOURCE: SD Card Wont Work
From the NV3 Manual: (specifications)
External memory(Optional) : MMC/SD card (Up to 1GB Guaranteed)
So the camera may not support a 4GB card.
Try 1GB cards (or smaller).
SOURCE: memory card full but its new!!!!
you may have a bad memory card as well. I had to return one a few months ago it was doing a similar thing. Try formatting it first, you may save yourself a trip.
SOURCE: Full Memory with new cards
Go into the camera setup menu and make sure you have it set to save images on the card, instead of internal storage.
SOURCE: memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
